por73911's Avatar
Please help if you can!!!!
OK here is the problem. I have removed my heat exchangers and I broke ALL of the studs! They look like they were some kind of "stretch bolts" as the were quite a bit smaller in the center. All of the studs have broken in the middle so none are flush with the case. What I have tried so far is....penetrating fluid with vise grips, heat with fluid and vise grips and welding nuts to the studs to try and get a grip on them. So with all of the effort I have removed 1 stud. So is there anything else I can try before I remove the engine and take it to the machine shop?
Thanks for any hep you can provide!
Paul
Old 04-23-2005, 06:39 PM
makaio's Avatar
Heat from an acetlyne torch, or mapp gas from a hardware store.
Old 04-23-2005, 06:47 PM
The Unsettler
stomachmonkey's Avatar
see this thread, currently towards bottom of page 1
Does anyone sell a fixture for drilling broken exhaust studs
good luck
scott
"I want my two dollars"
"Brandon Won"
Old 04-23-2005, 06:58 PM
Zeke's Avatar
Just keep at it. When you think of the alternative, it's worth hours under there. Here's one more method: Buy a LH and RH Easyout of the proper size. Use a Dremmel to provide a spot for an accurate center punch. Punch and drill the recommended hole size for your EO.
Now, heat and spray; insert LH (actually tightening) and give it healthy nudge (you NEVER want to break an EO off in the stud, you will have to remove the motor then), insert the regular EO and bump it. More heat, more spray and again back and forth. Once you hear it pop loose, you're on the home stretch.
Don't be too anxious, tho. You can still remove the threads form the head if you go too quickly. Get it to work free and unscrew it.
Old 04-23-2005, 09:22 PM
Detached Member
Hugh R's Avatar
Use the largest easy out that you can put in.You only get one chance. Buy high quality easy outs, don't go for the cheap ones, Snap on=Craftsman, etc., Good luck
Hugh
Old 04-23-2005, 10:40 PM
Send a message via AIM to fintstone
Take it to a good porsche shop or a machine shop before you mess up your heads.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 04-23-2005, 10:49 PM
