made the AFM mods
What mods did you do?
Joe
Old 05-13-2005, 09:07 AM
ausgezeichnet's Avatar
Removed the AFM, cleaned it, and adjusted the wiper arm so it had good contacts as documented at http://frwilk.com/944dme/
I also removed the mixture plug and played with the mixture. Ended up at 6 turns open. That was a while ago while I had some other problems. I 've corrected all of those and now it's time to make a more actuate measurement/adjustment.
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 05-13-2005, 09:22 AM
Mike,
I'm impressed!
Now that you got your hands inside the AFM, it would not be that difficult to tweek the mixture yourself by adding some spring tension or moving the pointer a few degrees back as long as you make a reference mark so you could put it back to where you started.
Make small changes, take it for a spin and see if it helps.
Cheers,
Joe
Old 05-13-2005, 09:53 AM
Joe,
Good idea. I remeber reading something about the spring tension. I'll take another look. Thanks.
-Mike
Mike
'83 911 SC Coupe
Old 05-13-2005, 02:10 PM
