RC-Escape's Avatar
Replace Front Brake Hoses
I was removing my front shocks today from a 1984 Carrera and I had to undo th brake hose from the fitting closest to the brake disc. No problem there, but I also want to replace the entire hose since it's orignal to the car. My problem deals with the hose fitting to the hard line on the inside fender. How do you get the hose out of the mount? I disconnected the hard line but couldn't get the hose line out of the mount. I tried to use pilers to hold the right side of the fitting while using a wrench to undo the left side (the 17mm nut side), but it didn't work! I'm doing something wrong here. Please help!
Rick
Bay Area, California
1984 911 Carrera Targa
1973 VW Beetle
Old 05-01-2005, 05:34 PM
dweymer's Avatar
I believe there is a small metal clip that slides into a grove in that fitting. It can be removed with pliers.
See here in red.
http://www.pelicanparts.com/catalog/images/brake_parts/brakes4.gif
Donnie
Currently Porsche-less.....
Old 05-01-2005, 06:30 PM
Correct about the metal clip.
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 05-01-2005, 06:32 PM
RC-Escape's Avatar
Thanks guys. I just went out into the garage and tried pulling that clip with pilers and it came out! All set now! Thanks Again!!!
Rick
1973 VW Beetle
Old 05-01-2005, 06:47 PM
RETIRED
Joe Bob's Avatar
Have fun breaking them loose....use flared end wrenches and patience.
2012 ML350 3.0 Turbo Diesel
Old 05-01-2005, 07:01 PM
