RETIRED
Joe Bob's Avatar
Looks to be a crappy two pole....crud.
2012 ML350 3.0 Turbo Diesel
Old 05-02-2005, 05:17 PM
RETIRED
Joe Bob's Avatar
This looks like the one I have....
Old 05-02-2005, 05:34 PM
lateapex911's Avatar
No matter how you fry it...pun intended???.....this is a place where you don't want re-engineer the wheel and gat fancy about it.
First, the switches are notorious peices o' crap. Get a good one because:
The last thing you want is an internal issue or a connection issue frying the alternator, or wiring etc, and the next to last thing you want is the thing to suddenly go down on you with the "2 to go" signal on grid.
Smart Racing has the best solution, and you can move on to other more important issues
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 05-02-2005, 05:42 PM
RETIRED
Joe Bob's Avatar
How about Flaming River....they are the ones sold at Summit Racing.
Old 05-02-2005, 05:53 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
I got mine from TRE, of this board..
It came with the alt resistor, (which you dont need if you wire up an ignition cutoff as i mentioned earlier.)
Marc
Old 05-03-2005, 07:15 AM
greglepore's Avatar
Well, I agree that if you cut the ign only the car won't run for long, but the alt is live as the engine spins down and I'm not sure the diodes like that, which is why the six pole switches both cut ign and provide alt with a load. Particularly big deal on a 914-6 where a fried alt means an engine drop on top of the alt expense.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 05-03-2005, 08:03 AM
I have a question.
If you do the connections like the Smart Racing diagram, will you have always a current flowing if the Switch is left in the off position?
Old 05-03-2005, 02:55 PM
RETIRED
Joe Bob's Avatar
Just ordered from TRE....
Old 05-03-2005, 03:06 PM
rattlsnak's Avatar
>>Well, I agree that if you cut the ign only the car won't run for long,<<
Uhm it wont run at all. Its instant.
I do understand the arguement of the Alt, but thats because most people dont wire in an ign relay cutoff. Pull switch and car cuts off instantly. No coil output., no run. Its doing the same thing as if you turn off the ignition key.
Marc
Old 05-03-2005, 08:10 PM
Zeke's Avatar
FWIW, apparently the factory knew how to do it with a 2-pole.
http://www.pbase.com/9146gt/for_sale_bosch_kill_switch
Old 05-04-2005, 05:52 PM
greglepore's Avatar
Its sort of the same thing as if you turn off the ign, but if you turn off the ign the alt still "sees" the bat as it spins down, 'cause its on the same terminal as the battery main-I understand that we're splitting hairs, but better safe than sorry.
The two pole works if you isolate the alt from the ign by running the feed seperate. John raises a good point about a long unfused run of wire, so I'd put a resetable 40 amp breaker or something inline close to the alt.
Greg Lepore
85 Targa
Old 05-04-2005, 07:33 PM
