1972 2.4L engine numbers
The eternal question. To rmove or not to remove the 74 2.7L engine from my 1972 911t Targa (early- # 32 off the production line) and replace with a 2.4 that is more original to the car. Does anyone know if the 2.4 engine numbers were different for the coupe and the Targa. I thought I read somewhere that the 9112_ _ _ _ number had a 9 following the 2 for engines that were original equipment on the Targa. Any help is very welcome. The idea being to perhaps find a 2.4 that is as close to the original as possible.
Chris M
72 TARGA . Sold 2009
70T Non-Sunroof Coupe.
Old 05-02-2005, 07:49 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
The 9xxx serials were sportomatics, the targa and coupe used the same numbers otherwise. Good luck
Scott Kinder
kindersport @ gmail.com
Old 05-02-2005, 08:17 PM
Grady Clay's Avatar
Chris,
Your VIN reflects the fact it is a Targa, not the engine number.
The VIN should be:
9112110032 (10 digits)
Where:
911 = Vehicle model
2 = 1972
1 = Engine type, 911T-E
1 = Body version, Targa
0032 = Sequential Number (32nd off the line)
The engine number would be close to:
6120032 (7 digits)
Where:
6 = Engine designation, 6-cylinder unit
1 = 911T-E
2 = 1972
To complicate things, if it was originally NOT a Sportomatic, the VIN would fall in the range 9112110001 through 9112111821. This would be for a ’72 911T Targa with a Type 915/12 transmission and a fuel injected (MFI) Type 911/51 engine.
If it was originally a Sportomatic, the VIN would be 9112119746 and higher. The engine would be Type 911/61 with an engine number of 6129001 through 6129293. The transmission would be Type 925/00 and a transmission number 762XXXX.
This is from the Porsche Spec Book printed in October ’73. There is some conflicting information.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 05-02-2005, 08:24 PM
Thanks guys, I am a little wiser. Interesting that the sportomatics use the 9 digit. I rechecked my VIN. It is 9112110037. Therefore it must be 37th off the line. It would seem I need a 2.4 as close to the number 6120037 as possible. Do you know if the crankcase would be aluminum ?
Chris
Old 05-02-2005, 10:43 PM
YTNUKLR's Avatar
Chris
It is magnesium, without a doubt. Or it originally was.
Scott Kinder
Old 05-02-2005, 11:47 PM
