1972 2.4L engine numbers
The eternal question. To rmove or not to remove the 74 2.7L engine from my 1972 911t Targa (early- # 32 off the production line) and replace with a 2.4 that is more original to the car. Does anyone know if the 2.4 engine numbers were different for the coupe and the Targa. I thought I read somewhere that the 9112_ _ _ _ number had a 9 following the 2 for engines that were original equipment on the Targa. Any help is very welcome. The idea being to perhaps find a 2.4 that is as close to the original as possible.
Chris M
72 TARGA . Sold 2009 70T Non-Sunroof Coupe. |
up-fixing der car(ma)
The 9xxx serials were sportomatics, the targa and coupe used the same numbers otherwise. Good luck
Scott Kinder kindersport @ gmail.com |
Chris,
Your VIN reflects the fact it is a Targa, not the engine number. The VIN should be: 9112110032 (10 digits) Where: 911 = Vehicle model 2 = 1972 1 = Engine type, 911T-E 1 = Body version, Targa 0032 = Sequential Number (32nd off the line) The engine number would be close to: 6120032 (7 digits) Where: 6 = Engine designation, 6-cylinder unit 1 = 911T-E 2 = 1972 0032 = Sequential Number To complicate things, if it was originally NOT a Sportomatic, the VIN would fall in the range 9112110001 through 9112111821. This would be for a ’72 911T Targa with a Type 915/12 transmission and a fuel injected (MFI) Type 911/51 engine. If it was originally a Sportomatic, the VIN would be 9112119746 and higher. The engine would be Type 911/61 with an engine number of 6129001 through 6129293. The transmission would be Type 925/00 and a transmission number 762XXXX. This is from the Porsche Spec Book printed in October ’73. There is some conflicting information. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 Last edited by Grady Clay; 05-02-2005 at 07:47 PM.. |
Thanks guys, I am a little wiser. Interesting that the sportomatics use the 9 digit. I rechecked my VIN. It is 9112110037. Therefore it must be 37th off the line. It would seem I need a 2.4 as close to the number 6120037 as possible. Do you know if the crankcase would be aluminum ?
Chris
Thread Tools | |
Rate This Thread | |
