BReyes's Avatar
Can cam chain housing be replaced without having to redo cam timing?
Thank You.
Regards,
Bernard
Old 05-02-2005, 10:13 PM
I do not see how.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-02-2005, 10:20 PM
BReyes's Avatar
That is what I was thinking but had to ask the question.
Bernard
Old 05-02-2005, 10:25 PM
essentially, yes, if nothing moved. engine at Z1 for #1 cylinder before disassembly. cam will stay put at that point with the sprocket off. mark sprocket to chain link, and which hole the pin was in. in combat conditions, it could be done within a couple tenths of a mm.
206 637 4071
Old 05-03-2005, 08:11 AM
BReyes's Avatar
Right side chain housing.
Pulley has decal "Made in Germany", and 3 marks
Does my pulley show Z1? Will check in morning.
What is the position for the right side? How do I check all is ok before turning engine over after reinstall sprocket. What tools do I need to do the sproket on the 3.2?
Regards,
Bernard
Old 05-04-2005, 12:40 AM
