NASA instructor
bornrich's Avatar
Fabspeed bypass - Causing low RPM Surging?
My 81 911SC has a surging issue at light throttle (stop and go traffic - ~2-2.5k), the engine surges causing the car to jerk slightly. I can also hear this at idle, the idle goes up and down a few 100 RPMs with a regular pattern.
As a side not I have the idle stabilizer disconnected due to the RPMS hanging up. It is a minor problem but it is so much smoother with out the sensor, especially since I have to deal with traffic on my daily commute.
My tech (Bob Grigsby) tells me this is due to the location of the O2 sensor in the bypass only sensing on side of the engine. My Tech's explanation sounded logical since the bung locates the sensor in the path of the upper tube of the bypass thus getting only the mixture from one side of the engine. To eliminate this surging I have disconnected the O2 sensor but this causes poor gas mileage. I have had Bob check the mixture and anything else he cam think of that would cause this behavior. My gas mileage is poor but the car runs great.
I contacted Fabspeed and they said they have had no complaints and that my tech is incorrect in his evaluation.
Is there a fix for this behavior? Has anyone else experienced this surging with the Fabspeed bypass?
Matt Rich
1999 Porsche 911 Zeniith Blue
1999 BMW 540i
2011 BMW 535i
Old 05-06-2005, 08:56 AM
Bye, Bye.
Scooter's Avatar
Check the O2 sensor for damage. That is about the limit of my knowledge on this topic, but I do know that John Walker would be the guy that I would be talking to. Try shooting him a PM, maybe he could give you a second opinion (from your wrench, not me). Good luck and drive safe!
Elvis has left the building.
Old 05-06-2005, 09:53 AM
Bill Verburg's Avatar
O2 sensor would be the first thing I would look at also. Sounds like lean surge.
Bill Verburg
Old 05-06-2005, 11:05 AM
NASA instructor
bornrich's Avatar
I replaced the sensor when I initially installed the bypass in 02 and my tech replaced it again this past fall after my smog test and subsequent re-installation of the bypass. So I don't think it is the O2 sensor.
Matt Rich
1999 BMW 540i
2011 BMW 535i
Old 05-06-2005, 12:52 PM
NASA instructor
bornrich's Avatar
Bump - help!
Matt Rich
1999 BMW 540i
2011 BMW 535i
Old 05-12-2005, 02:45 PM
Designer King
Paulporsche's Avatar
A fluctuating idle usually indicates a too rich mixture. On my car (no O2 sensor) that same too rich mix also shows up as low speed, part throttle surging.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-12-2005, 02:59 PM
NASA instructor
bornrich's Avatar
My car does not surge with the O2 sensor disconnected (should be running richer). With the sensor connected it does surge. This is driving me crazy.
One message said it might be lean surge. That seems more likely, but then I know next to nothing about fuel injection. I will talk to my tech once again.
Matt Rich
1999 BMW 540i
2011 BMW 535i
Old 05-13-2005, 08:38 AM
