84Carrera911's Avatar
Simple Toggle switch question
I am a somewhat rookie wirer, and I was wondering if you can hook a toggle switch up to a ground wire instead of a hot. Will this drain power or anything?
Old 05-06-2005, 05:55 PM
MBAtarga's Avatar
What are you trying to do? The answer is no, but what are you connecting the other side of the switch to?
Mark
'83 SC Targa - since 5/5/2001
Old 05-06-2005, 06:07 PM
coloradoporsche's Avatar
As Mark points out...no.
You can, generally speaking, switch a circuit on the ground side. But cars are tricky because sometimes you are grounding by simply attaching whatever it is you are working on to the car itself. If whatever it is you are working on is completely ungrounded, your switch should work.
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 05-06-2005, 06:23 PM
Many newer vehicles (often Japanese) locate the switch as well as relay on the ground side of a circuit.
Sherwood
Old 05-07-2005, 09:01 AM
You can put the switch anywhere in the existing circuit as long as it can close and open the circuit.
Old 05-07-2005, 09:22 AM
Still Doin Time
asphaltgambler's Avatar
Depending on the circuit you are control-switching, many guys like to control the ground side because it usually means less wiring and there's not an additional 'hot' wire that could potentially ground/short and cause big problems.
Many auto manufacturers do this in their electrical systems.
Old 05-07-2005, 09:28 AM
Alright, I put it on the ground side and it works great! It also has less wiring. Thanks guys,
Tommy
Old 05-07-2005, 01:33 PM
