Simple Toggle switch question
I am a somewhat rookie wirer, and I was wondering if you can hook a toggle switch up to a ground wire instead of a hot. Will this drain power or anything?
What are you trying to do? The answer is no, but what are you connecting the other side of the switch to?
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
As Mark points out...no.
You can, generally speaking, switch a circuit on the ground side. But cars are tricky because sometimes you are grounding by simply attaching whatever it is you are working on to the car itself. If whatever it is you are working on is completely ungrounded, your switch should work.
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
Many newer vehicles (often Japanese) locate the switch as well as relay on the ground side of a circuit.
Sherwood |
You can put the switch anywhere in the existing circuit as long as it can close and open the circuit.
Still Doin Time
Depending on the circuit you are control-switching, many guys like to control the ground side because it usually means less wiring and there's not an additional 'hot' wire that could potentially ground/short and cause big problems.
Many auto manufacturers do this in their electrical systems.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Alright, I put it on the ground side and it works great! It also has less wiring. Thanks guys,
Tommy |
