2.7 engine swap - '76 into '74 Question
I am planning to drop a 2.7 engine 1976 into a '74 911S. Is this a straight forward swap?? Any differences or things I should know?
Thanks a lot,
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 05-07-2005, 12:30 PM
Warren Hall Student
Bobboloo's Avatar
It's pretty straight forward. The main difference between the motors was the exhaust system. Ideally you should keep the 74' exhaust system and install it on the 76' motor. It'll give you extra horsepower and extend the life of the 76' motor. Now's the time to do it since both motors will be out.
I don't know what state your in but you should also remove the smog pump system and plug the holes in the cylinder heads if allowed in your state.
The most important thing is to be extra careful when removing the old exhaust system you don't want to break off any studs. Soak the nuts overnight with PB blaster and then use a torch and heat the nuts until they glow red before you attempt to remove them.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 05-07-2005, 12:55 PM
Thanks for your reply. Do you know if there is any differences in the wiring?? Thnaks
Mario
'15 GT3
Old 05-08-2005, 11:59 AM
Author of "101 Projects"
Wayne 962's Avatar
There were so many minor variations in the wiring amongst the years, even small differences sometimes between Euro and USA cars. Believe it or not, this is not a super-common swap (most people swap in a 3.0L).
Take the old engine out and compare the wiring harnesses. At the very least, if they are identical, then you should have no problem. If they are different, the quick and easy solution is to keep the 1977 fuel injection on the 1974 engine - since the long blocks are basically the same, you should have no problem.
The 1974 motors came in a 'S' and non-'S' version, the only main difference being the cams and the pistons. All of the 1977 2.7 engines were 'S' models. That said, the CIS system should still work fine on an 'S' or non-'S' longblock, but you may want to double-check the final mixture when you're done...
-Wayne
Old 05-08-2005, 12:13 PM
pjv911's Avatar
Send a message via AIM to pjv911
Some 76` models had power brakes . It your engine is equipt for that you will need to plug the 1/2" nipple on the air box . But I would recommend exactly what wayne suggested . Swap the entire injection system. Also the fan/alt due to any possible differences with the voltage regulator. Take it all off in one big assembly . Dont drop any hardware down the ports !
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 05-08-2005, 12:21 PM
[i]... If they are different, the quick and easy solution is to keep the 1977 fuel injection on the 1974 engine - since the long blocks are basically the same, you should have no problem.
-Wayne [/B]
Wayne, sorry but I lost you. You mean to put the '74 injection on the '76 engine??
The reason for doing the swap is that the '74 engine is blown.
Mario
'15 GT3
Old 05-08-2005, 03:05 PM
pjv911's Avatar
Yes thats what he means .
Old 05-08-2005, 03:12 PM
