wow, great thread! missed it before...
911 3.2 custom fiberglass heater tube
http://forums.pelicanparts.com/uploa...1265042900.jpg
picture of the two parts before i painted with trim black paint. http://forums.pelicanparts.com/uploa...1265042934.jpg just modified the original parts so the upgrade was freeeee! |
I subscribe as well!http://forums.pelicanparts.com/uploa...1265046707.jpg
From the tiny switch at the red levers, can you just connect them directly to the foot blowers, with a relay to get power from the ignition?
The resistor idea did not work, however, thanks to the hard work of fellow Pelican, Mysterytrain, we found that a simple crossover of the reed switch solves the problem. Read through this thread for how to do it. http://forums.pelicanparts.com/porsche-911-technical-forum/258473-help-does-anyone-understand-footwell-blower-circuit.html |
http://forums.pelicanparts.com/porsche-911-technical-forum/388445-carrera-removing-engine-compartment-heater-blower.html I also included a modification to toss out the complicated stock relay box and replace it with 2 simple relays or (just one simple relay for backdate). |
Thanks for all the great detailed information Sal, Ron and others.
I was just looking into backdating my heat and saw on Thom's site that he stopped taking orders for the Left side piece in 2006. Where is everyone getting this piece now? |
subscribed
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/520521-wanted-left-right-heater-ducts-duct.html |
Thrasher,
I purchased mine from our host. |
How much modification is required for the left side duct on a Carrera? It seems like the feedback on the parts is that you need to do some metal shaping with a hammer??
-Jack |
Jack,
The drivers side on my 85' Carrera pretty much bolted right up, I had more trouble with the passenger side. |
Why stop with the heat and go all the way backdating, before
http://forums.pelicanparts.com/uploa...1265850818.jpg and after. Note the street elbow on the right side, cheap and easy. http://forums.pelicanparts.com/uploa...1265850908.jpg keep up the great work guys!!! |
Reviving this thread as I am in the process of backdating my Carrera. What did you do with the blower power connector? And do you "shape" the left side duct near the dizzy while bolted on or should I remove it, ballpeen a bit and reinstall? It needs adjusting to get the dist cap on. What would you do?
ball peen jobs kinda look like that. cut out a nice curve, then weld a curved piece of 20ga sheet metal in, grind it out nice and paint.
Thanks John. You're right, that's what I will do. How about the electrical connector? Tape the connector end and Zip tie it to the ?
I've been trying to locate this reproduction heater duct but having no luck. I don't wish to purchase a metal one and fab to fit around my distributor.
Does anybody know where I can find this now???? http://forums.pelicanparts.com/uploa...1321932078.jpg |
My backdate. The heater still works just fine.
http://forums.pelicanparts.com/uploa...1321933271.jpg http://forums.pelicanparts.com/uploa...1321933282.jpg |
I have a FG version that Thom used to sell here years ago. I ended up having to peen it to clear my 964 distributor, then reglassed the indentation.
Maybe a WTB post in FS would turn one up? |
| All times are GMT -8. The time now is 06:35 PM. |
