Va914's Avatar
HELp with Dizzy ID
The engine is a 2.2T
The markings on the side of the dizzy are;
0231159 006
JFD6
B231068081
Can anyone ID this as the correct dizzy for a 2.2T with carbs?
Cheers
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 05-10-2005, 04:43 PM
B D B D is offline
B D's Avatar
No, that the one for a E.
http://www.boschusa.com/AutoParts/PartFinder/PartFinderResults.asp?selYear=1971&selMake=PORSCHE&selModel=911_E&selEngine=H6-2.2L%20VIN=2%20GAS
Here's a ugly cut and paste from the Bosh site:
Part Number Description Where to Buy
0 986 237 000 Distributor-Exchange Model S Locate Retailer
01026 Points Locate Retailer
N.R. Condenser Locate Retailer
0 231 159 008 Distributor-New Model T Locate Retailer
0 231 159 006 Distributor-New Model E Locate Retailer
04023 Rotor Model T Locate Retailer
00025 Coil Locate Retailer
04029 Rotor Model S Locate Retailer
04028 Rotor Model E Locate Retailer
0 227 200 001 Transistor Unit - New Locate Retailer
0 231 159 007 Distributor-New Model S Locate Retailer
03014 Distributor Cap Locate Retailer
68 911L
Old 05-10-2005, 05:32 PM
Va914's Avatar
Okay so now the BIG question. I was told by the PO of this engine it was a 2.2T engine. Will that dizzy work on a 2.2T engine?
I think the engine code confirmed it was a T but I guess he could have changed things up some.
914-6 in the Werks
Old 05-11-2005, 03:50 AM
'72, '73 Tech Spec book lists T, E, and S having the same advance curve.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-11-2005, 07:10 AM
