HELp with Dizzy ID
The engine is a 2.2T
The markings on the side of the dizzy are; 0231159 006 JFD6 B231068081 Can anyone ID this as the correct dizzy for a 2.2T with carbs? Cheers
Kerry (Back on the road, sort of) 914-6 in the Werks |
No, that the one for a E.
http://www.boschusa.com/AutoParts/PartFinder/PartFinderResults.asp?selYear=1971&selMake=PORSCHE&selModel=911_E&selEngine=H6-2.2L%20VIN=2%20GAS Here's a ugly cut and paste from the Bosh site: Part Number Description Where to Buy 0 986 237 000 Distributor-Exchange Model S Locate Retailer 01026 Points Locate Retailer N.R. Condenser Locate Retailer 0 231 159 008 Distributor-New Model T Locate Retailer 0 231 159 006 Distributor-New Model E Locate Retailer 04023 Rotor Model T Locate Retailer 00025 Coil Locate Retailer 04029 Rotor Model S Locate Retailer 04028 Rotor Model E Locate Retailer 0 227 200 001 Transistor Unit - New Locate Retailer 0 231 159 007 Distributor-New Model S Locate Retailer 03014 Distributor Cap Locate Retailer
68 911L |
![]() Okay so now the BIG question. I was told by the PO of this engine it was a 2.2T engine. Will that dizzy work on a 2.2T engine? I think the engine code confirmed it was a T but I guess he could have changed things up some.
'72, '73 Tech Spec book lists T, E, and S having the same advance curve.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thread Tools | |
Rate This Thread | |
