911E Tach, 70 vs. 71 & later
Does anyone know what the difference is between a 70E tach (911.641.302.00) and a 71 and later (911.641.302.01)?
Are they interchangeable?
Dave
1969 911T Coupe
1972 911E Targa
Old 05-11-2005, 06:47 PM
Anyone?
Dave
1969 911T Coupe
1972 911E Targa
Old 05-12-2005, 10:39 AM
randywebb's Avatar
at some point in the early/mid 1970s the electronics changed, could be that point
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-12-2005, 10:49 AM
Early_S_Man's Avatar
Porsche Crest
Dave,
I don't have info on the specific pn's you posted, but, as Randy said ... there was a change around that time to eliminate the elusive 'Ballast unit' ... a resistive 3-terminal divider circuit that was used with the early tachs vs. the later tachs that were simply triggered by the points!
You probably can't directly interchange them with out wiring changes, but the changes are pretty simple! A later tach replacing an early one is the easiest change ... just move the Black/Violet tach trigger wire to the points input at the CDI unit!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-12-2005, 12:10 PM
Thanks for the info, guys.
Of course, I've got the difficult case...70 NOS E tach and 72E needing tach.
Dave
1969 911T Coupe
1972 911E Targa
Old 05-12-2005, 06:36 PM
randywebb's Avatar
I posted a thread some time ago on this, but I don't hink it will help you. It related to 1973 and later I think.
I guess you could try... be sure to post results for the next person.
Old 05-12-2005, 10:09 PM
