Back Date Exhaust 82 SC o2 sensor ?
I assume that you must locate the o2 sensor somewhere in the early exhaust when back dating the exhaust on an 82 SC. Do I put a bung just past the collector? Any advice or pit falls with this modification other than emmissions?
Thanks |
Friend of Warren
If you buy SSI's the 02 bung is already installed.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I have a pair of nice early heat exchangers. Where is your fitting located?
Hi,
sorry for being ignorant, but can some one explain on what is back dating?? Does it mean to completely remove the heat exchangers and replacing with headers?? can i do this on my 84 carrera? ~onsse
02 GSXR 1k 97 C4S 97 TT 84 Euro (sold) |
Driving member
Backdating simply means taking a later car to earlier car design. In this case backdating exhaust is going to pre 74 exhaust setup.
The search button will bring many things about this subject.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
thank you.... will be researching... for more...
here's one I added to mine a few years back
onsse, yes but for your car the results are so/so. Emission inspection concerns can be a big issu as well. a search will be fruitfull
Disbanded
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
