So far I have posted everything I know on the Triad muffler. No connection to Triad other than close in local (NW). I liked the original Triad design for the 993 engines because it some what resembles the 993 factory stuff. (there are two other 3.6 Triads here on Pelican)
I have a lot more room under my rear bumper than I did with a Danske or a Monty on my 3.4.. That has to help keep the 3.6 engine running cooler. Muffler is the lowest noise signatures of any 3.6 911 transplants...and compares well with current factory cars. Most importantly it sounds nice. These pictures are from the original fitting at Eurotech. I'll get a new dyno for comaprison this week and get the muffler coated for durabilty and post more info when I get a chance. But yes $550 was the retail I paid from Dave @ Triad. ![]()
Administrator
That's a beautiful color.
Congratulations on finishing, Dane!
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Sports Purpose 911 Driver
looks great Dane!
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Thanks guys! Lots of inspiration on Pelican for some great projects.
Here is my final build sheet for those that are interested. I hope it helps you on your project! 1979 SC (USA) in Moca brown, original “cork” leather interior purchased in stock condition @ 179,000 miles on 8/30/02 All current work done by Eurotech Bodywerkes, Kirkland WA. Bare metal respray Glasurit blue Current weight: 2134# with 1.5 gallons of gas on board and full up on oil. 280hp at the wheels BODY WORK: New German windshield with radio antenna and seal Stoneguard 3M bra and car protection (yet to be added) Reversed wiper arms one wiper delete rain gutter delete MA Shaw fiberglass ducktail GT Racing fiberglass hood with RS support C4 head lights with 55/100s, wiring relay installed & painted trim rings GT Racing IROC front bumper cut and fit to flares custrom Kevlar splitter MA Shaw YB rear bumper, aluminum heat shield mount, custom fit to flares Reweld of the unibody @ rear torsion tubes and engine compartment Rocker, radio antenna, gas fill and flag mirror delete Sunroof delete WEVO battery box in the smuggler's position. West Coast, compact Miata battery Body tub cut for a TRE oil cooler fresh air scoop rerouted oil lines New window/body seals 911 R rear tail lights CUP window washer tank Hand dollied 8.5 " front and 10.5" rear flares front and rear tow hooks Fuelsafe 27 gallon fuel cell- hidden center fill ENGINE: 1995, 3.6 Porsche flat six factory dual plug system EBS HD value springs and Ti keepers RS 3.8 cams with hydraulic lifters Triad 993 sport muffler w/ceramic coating B&B stainless front bumper oil cooler Fabspeed air box cover OEM Club sport mounts on the engine Custom exhaust heat shield on rear bumper High Torque IMI, light weight starter TRANSMISSION: OEM Club sport mounts on the transmission rebuilt '78 915 (zero miles) standard box top speed est 175mph at 7K. New Turbo syncros 5/14/04 Factory ZF limited slip, set @ 80% Sachs Power Clutch Patrick high performance lwt flywheel WEVO short shifter and coupler WEVO internal gate WEVO bearing retainer BRAKES: Braided stainless steel brake lines SCI 930 brake conversion from a ’86 with slotted, floating front calipers and OEM cross drilled rear rotor Shaved front calipers to clear 7" Fuchs, calipers relogoed New 930 master cylinder Ferodo FDB 451 high performance street/track pads air kit ducted to IROC bumper SUSPENSION: Elephant Racing triangulated cross bar 22 front with 30 rear, Sander's hollow T bars 22 front and 21 rear stock OEM ‘86 Carrera sway bars Elephant front mono balls Elephant polybronz control arm bearings Elephant low friction control arm mounts Elephant rear monoballs Wevo spring arm plates with steel bearings solid bushings (nitrex ) all around for the rest Bilstein sport shocks on the rear Custom valved Bistein Sport front shocks for this car's power and weight new ball joints Turbo Tie rods Alignment, corner balanced, lowered by Tru-line Seattle WHEELS and TIRES: Factory Fuchs. '86 930 9x16 wheels on the rear '86 944 8x16 wheels on the front SO3s in 225/245 sizes INTERIOR: SafeCraft 5# Halon 1301 Fire system, pull cord activation, plumbed for single cockpit and with dual nozzles in engine compartment RS door panels in Porsche cork Custom Recaro leather, Pole Position seats drivers bolted to floor, passenger has dbl., adj. Porsche rails Custom "cork" inserts for the Pole Position seats Custom RS style carpet set from Bently wool carpet in black Momo m7, 3 spoke, classic, leather trim, road wheel Tekniqauto quick release hub with horn AJ USA billet aluminum peddles and dead peddle Custom North Hollywood guages Alpine CDA 7875 AM/FM radio and CD player New German headliner New body seals TRE RSR roll bar with braces welded to sill and B pillar Last edited by rdane; 05-15-2005 at 09:40 PM.. |
Senior Member
Looks great! Am working on my exhaust right now as well!
Joe A
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Light,Nimble,Uncivilized
Uhm...that's a pretty nice build sheet you have there Sir (understatement of the year).
Now, it's time to drive.
Drago '69 Coupe R #464 |
Information Junky
Im bummed I missed ya Dane. (a few of use drove over to Roslyn after .. .see NW board)
So, I seem to have missed, in your list there, the super-aero- side-view mirror video camera. Sure looks sleek though. ![]() . . .love that duct shot.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
How bout some before and after pics? Beautiful job Rdane. That car is going to be a blast.
1980 911SC Targa 3.6L |
Mirrors? You need mirrors?
I do have a rear view mirror and a flexible neck. |
Hoser.
Quite nice-can't wait to see more pics.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Bird. It's the word...
Congrats Dane, job well done!
John Forcier Current: 68L 2.0 Hotrod - build underway |
Thanks Guys. The first weekend with our stock '79 SC. The beginning. ![]() The same car with a spec 3.4 and a Ruf body and new interior. The first "finished" car. Stage two where we started the "final" version. ![]() Our same car in its final version, stage 3, the "RBRDUK". Only the wheels will change now. Better pictures when we get sunshine again. ![]() But I really like Drago's shot. ![]() Looks like something close to 175 mph top end if I can keep it on the road
Information Junky
Dane, you have quite a nice flair for 911-balance there.
Thank you Island. I'll take that as a big compliment knowing the source
But the bow really goes to the guys at Eurotech. They did an incredible job of putting my ideas into art work done in metal.Last edited by rdane; 05-15-2005 at 06:46 PM.. |
Sorry I missed it Dane. I arrived at the XXX just after noon as I had some crazy idea the "drive" was at 2:00 pm...Most everyone was gone. I'll see it next time. Great job on this project!!!!!!1
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Guest
Posts: n/a
She looks delicious!
Guest
Posts: n/a
Um, where does the gas go in?
Information Junky
It has copper brushes underneith, and only runs on a special track.
Did you post a pic of the aluminum heat shield for the muffler and how it's mounted? I don't think I saw that.
Also, you misspelled Recaro - so I put the word here in case somebody searches for Dane + Recaro to look at the your interior... Great looking car & xlnt documentation for others. I'll look fwd to seeign some on the road pics of the color - both coludy days & sunny...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
