-2 wheel offset? BBS
I'm looking at a set of wheels that the seller claims have fit on an SC
He said the offsets are 8x16 e11 (Which he had on the front) and a 9x16 -2 (Which he never used) Anyone know if that is corrcet? I have an early 911 with RS flares |
MBruns for President
I doubt it - should be 23-26mm offset in the front and 11-16mm offset in the rears - that is what my bbs offsets are.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Look here for lots of wheel fitment info
http://members.rennlist.com/1976c38/index.html |
Schleprock
Ask him to send you a picture of the wheel. You'll know right away if the -2 o/s is true. The wheel will have a rather deep "dish" to it.
If it is indeed a -2 o/s? I don't think it'll fit your car. The negative o/s would push the outboard wheel edge too far outboard and you'd have fender-tire clearance problems. And the +11 o/s wheel would not fit the front either. This 16x8 offset is typically what is used on the REAR of a SC or Carrera. If you were to mount the wheel in front, the wheel sits ~ 1/2 in. further outboard than the typical maximum 16x8 that people run up front. I find it surprising that the guy said he ran them on a SC. Both offsets mentioned are beyond what is known to fit on a SC-bodied car.
Kevin L '86 Carrera "Larry" |
