KCinBR's Avatar
Strut insert install question
I installed new koni inserts saturday in my 88 targa.
I removed the large rubber bushing (not sure of name) from the upper strut mount where the strut goes through the body of the car. I had to destroy the rubber part to get it out. It was replaced by a 2 piece rubber mount and large washer that came with the koni inserts.
My question is......have I screwed up by removing the original rubber piece?
I have driven the car since and have no adverse affects and it handles much better than before, but I'm not sure if I have screwed up.
Impatiently awaiting a reply
Thanks.............KC
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 05-16-2005, 06:50 AM
450knotOffice's Avatar
Bump for a fellow Pelican in need. I hope you find your answer.
Old 05-16-2005, 10:40 AM
Glasgow 911SC's Avatar
Just to be precise, which part on here are you talking about?
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 05-16-2005, 02:56 PM
Banned
fastpat's Avatar
Is number six in that drawing the spacer on US-spec cars?
Old 05-16-2005, 04:54 PM
anthony's Avatar
I think #6 is the metal sleeve that is inside the rubber bushing (inside #8?) at the top. In any case the ride height spacer is much wider (1.5" in diameter maybe).
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 05-16-2005, 05:04 PM
KCinBR's Avatar
The Part I'm talkin about is the large rubber donut looking thing that would be in #8. I removed the one that was original equipment on the car and replaced it with the rubber washers ( large and thick) that came with the Koni inserts.
Here's a pic of the part keep in mind I had to cut part of the rubber off to remove it,
Just trying to be sure I have not made a mistake by removing the rubber peices.
Thanks............KC
KC
2005 Boxster S
Old 05-16-2005, 05:38 PM
Nope, no mistake. I reused the old ones on my car because they'd already been compressed a bit and I couldn't get the nut on the insert with the new ones, but when I did the job I found people who'd managed to.
You're all good.
1968 911L
2004 Dodge Dakota SLT Plus
Old 05-16-2005, 06:14 PM
