I bought an aftermarket condenser from www.iceac.com. Here's a picture in the front left fender, without the rock guard I fashioned:
http://forums.pelicanparts.com/uploa...1116346717.jpg I straightened out the bent fins before I buttoned everything up. |
Ok, im thinking now of simply mounting the 993 condensor in the front wheel well, along with the stock front condensor, eliminating the rear condensor, new lines and a sanden 507.
ryan |
The 964\993 style is much more efficient and incorporates a fan and shroud to maxamize air flow. The 911 AC problem is mostly heat transfer from the condensor becasue of poor air flow and is compensated by adding more condensor surface area. The 993 has great AC and does not need multiple condensors.
Make sure the condensor setup you buy has the bracket, shroud and fan included. Additional custom mounting brackets have to be fab'd to do the install and does require removal\relocation of the washer resevoir and the gas tank expasion chamber. |
ryan |
More condenser surface = more cooling. |
More air into the engine comaprtment for better cooling
rip out the ac and move to alaska. that should lower your vent temperatures...
My $.02, but I'd be interested to hear what others think. |
My engine did run slightly cooler (according to the oil temp gauge) by removing the non-used condensor
Hey, im just exploring options here..
with the air conditioner on, how much heat is coming off that rear condensor? maybe enough to warm the air a bit?
i took the AC out of a 75 car, and i noticed temps lower at the gauge too. i cant explain it, tho. maybe the increase of the opening in the lid? |
If you use an 993 condenser it's going to take a lot of work to make brackets and relocate the stuff in the left hand wheelwell. |
The rear condensor gets almost too hot to touch when the AC is running on a hot day. The in and out connectors will easily burn bare skin. Removing it will definately give the engine much cooler air.
The rear lid condenser is dumping heat on the engine and in return raising engine temps..not a major issue when you are moving but when stopped in traffic the engine fan just is not pulling alot of air. The under belly condenser will supply more surface area ( a good thing) but..in stop and go traffic you have the same problems..reduced air flow and that heat is now coming up thru the floor..again not an issue when you are moving. The dream has always been to remove the rear lid condenser and go with something under the drivers side fenders like griffith or the 964. I've done lots of homework on this approach and most of the threads that have been started regarding this type of modification have no follow-ups as to how the project turned out. I have often wondered if the 964/ 993 condenser assembly would fit in the rear fender like griffiths...making it possible to run two units if needed? Performance Aire also makes a new improved three layer rear condenser that looks interesting unfortunately I haven't heard much about the operation of that unit. I like the looks of the new retro air evaporator seems like a good way to go. Another strange A/C issue that has always puzzled me and is never addressed here is the return air plumbing. On the passenger side it is behind the floor board and flow is really effected by carpeting. The Drivers side is more of a joke..you have that big ol' 3.5" or so duct from the evaporator that goes to an opening behind the gas pedal..then you throw some carpet on that and reduce the opning even more. I've often wondered why they didn't use the center tunnel to pull air from vents that could have been located under the seats. Anyway..how about you A/C pioneers reporting back to us all on your systems, the components and what works and what doesn't.
The more condenser area the better.
I always kind of roll my eyes at the Procooler. Maybe it works. It's not clear to me why it would do all that much, and the manufacturer has never had it tested, as far as I can tell. But I'm not an AC expert by any stretch, just a consumer -- and I doubt it hurts a system's performance. But I don't know if the expense is justified. More condenser area is definitely going to help. A good compressor is definitely going to help. Getting all the basic components, like the hoses and evaporator, up to snuff is definitely going to help. A lot of times, all of this is done when the Procooler is added, and I think its perceived benefit grows as a result. |
$400 for the underbelly seems good, You can really jack the car up with it?
| All times are GMT -8. The time now is 08:45 PM. |
