too lean or too rich?
So far so good for my '77 2.7 cis "MM" engine. I have almost 2,000 miles on it and many at 5,000+rpm. However, after the engine cools down, it doesn't want to start. It 'seems' like it isn't getting fuel or? It feels like I should 'pump' the gas pedal. (I know) It cranks over very fast, and after a while it almost wants to start, but doesn't quite make it. Is there a step by step elimination procedure that would lead to the problem?
Old 05-13-2005, 07:30 AM
Senior Member
Superman's Avatar
You probably have the common hot start problem because residual pressure is bleeding off your fuel system due to a leaking check valve, fuel accumulator or injectors.
Mocha 1978 911SC. "Coco"
Old 05-13-2005, 07:33 AM
klaucke's Avatar
Do a search, there are a bunch of threads on cold start and hot start problems. Could be a problem with your WUR, check valve, fuel accumulator, etc. You may start by checking the cold pressure of your WUR, to eliminate that possibility. Normally the WUR can cause cold start problems.
Old 05-13-2005, 07:37 AM
I searched and found some great discussion and learned what WUR stands for. However, 1) where is the darn thing, and 2) how does one know if it is broken, and 3) which way do you turn it?
Old 05-13-2005, 07:50 AM
Somewhere in the Midwest
MotoSook's Avatar
Oh boy...do you have a lot to learn no, really, read up on CIS, wish Jim Williams' page...
Old 05-13-2005, 09:06 AM
Do a search on residual pressure.
Joe
Old 05-13-2005, 09:16 AM
Ah ha! I found the little bastard as well as the aticles. I'm sure I'll be ready for a quiz in no time. Thanks! (I think)
Old 05-13-2005, 09:39 AM
scottb's Avatar
"so far so good" and "MM engine" in the same sentence? You don't see that every day.
1984 Targa
Old 05-13-2005, 10:04 AM
nixter's Avatar
I had/have the same problem. Unfortunately the cause has not yet been totally sorted. Here's my thread..
New plugs didn't fix it :(
Nik
1980 911 SC widebody, Black/Black.
1993 BMW M5. Silver/Black.
Old 05-13-2005, 10:05 AM
WUR not it
2 questions:
Well I r&r'd the WUR today, but the car still won't start.
1) So, is there anything else a DIYer can r&r? Or is it time for my mechanic to fix it? I just hate towing it.
2) Do you think it would push start?
Old 05-21-2005, 02:50 PM
ianc's Avatar
Too bad you got put down the wrong path at the start with the WUR, which will really only affect cold starting and running.
Look at the accumulator and fuel pump check valve as mentioned earlier. You will need the fuel pressure gauge to check these properly.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 05-22-2005, 09:17 AM
