Kevin Stewart's Avatar
Is there anyway to test an oxygen sensor 3.6
Ok my sc is smokin raw fuel(remember i have no miles on the 3.6, it starts so i beleive that its not flooding until it starts, it will clear up after awhile, car was last started 3 onths ago, would the oxygen sensor being bad cause it to load up, also, is there anyway tyo test it, Kevin
Old 05-22-2005, 09:26 PM
I think the oxygen sensor just fine tunes the air fuel mixture at cruise and idle. If it is blowing black smoke I wouldn't think the OXS is at fault
Old 05-23-2005, 08:15 AM
its actualy a blueish white smoke and smells extremely rich, Kevin
Old 05-23-2005, 10:21 AM
Porsche Junky
mede8er's Avatar
Installing a diagnostic port for your particular 3.6 is a good start.....
Others have posted some good info on this subject....Moses comes to mind.......
1986 930 RUF equipped
Old 05-23-2005, 10:27 AM
Im also thinking that there may be a check valve somewhere, it smells like gas just sitting there, Kevin
Old 05-23-2005, 11:19 AM
Bill Verburg's Avatar
Set up a diagnostic pigtail at the connector in the engine compartmant
spec is fluctuationg between 0.1 and 0.9vDC
you can induce a lean condition by undoing the oil filler cap.
Bill Verburg
Old 05-23-2005, 02:36 PM
Set up a diagnostic pigtail at the connector in the engine compartment
Bill Verburg
any one have a wiring idea for this, Kevin
Old 05-23-2005, 06:01 PM
CBRacerX's Avatar
What harness and brain are you using?
Chris
3.6 conversion that used to be _super_ rich
Chris
https://dergarage.com
‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900
Old 05-23-2005, 07:14 PM
I have a 93 motor with the stock brain, Kevin
Old 05-23-2005, 07:20 PM
CBRacerX's Avatar
Check the head temp sensor. It can keep the car rich despite being warmed up when it goes bad. You can check the resistance of it or just install a new one, Pelican has them pretty cheap.
Chris
Chris
Old 05-23-2005, 07:24 PM
