Forced Induction Junkie
WERK I's Avatar
Carrera(80's) w/fog light help
Some time ago my high/low beam switch failed. I replaced the unit, but ever since, my fog lamps have never worked. The indicator lamp in the pull switch(fog lamps) comes on but no fog lamp illumination. I think I may have accidently mis-wired the parking/headlamp switch. Does anyone with an 80s' era Carrera have a diagram or pic of the switch and its wiring?
TIA
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 05-23-2005, 12:32 PM
bigrubberjeep's Avatar
This probably isnt much help, but I do know that when I have my fog lights on and go to high beam, my fog lights automaticaly switch off.
I'm not sure how that might help, but I figured it may be worth looking into
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 05-23-2005, 01:30 PM
WERK I's Avatar
bigrubberjeep,
Yes, that's how mine worked originally too. Foglamps would also come on when the parking lamps were on(Fog Lamp switch On). I think the wiring for the foglamps to the headlight switch may be wrong.
Dave
Old 05-23-2005, 02:01 PM
87coupe's Avatar
A quick search yielded the following about fog light wiring:
Fog lights non-functional See Fred Cooks response towards the bottom
as well as this post
wiring diagram for fog light switch 71?
The search is a powerful tool
ßrandon
Old 05-23-2005, 02:20 PM
WERK I's Avatar
Brandon,
Yes, the search tool is powerful.
I was hoping I wouldn't have to go thru that convoluted wire harness under the bonnet to track the problem. Since I only replaced the high/low beam selector switch, when the problem manifested itself, maybe someone could show me the proper connections at the back of the headlight/parking light switch.
Dave
Old 05-23-2005, 03:25 PM
Hope it helps
Old 05-24-2005, 07:47 AM
WERK I's Avatar
donporfi,
Yes, thank you very much, it does. I wish the pic were a little bigger. I tried saving the image, but when I do, the enlargement is too blurry to read the pin numbers on the switch/relays to make it useful. Is there anyway you could save a larger/higher res image?
Dave
Old 05-24-2005, 08:32 AM
Fog light switch from top to bottom
15 gry,1 Blu / Wht,31 Brn,58 Blk / blu
Turn signal / headlight dimmer switch from top to bottom
30 red / wht
56b Gry
Old 05-24-2005, 08:55 AM
WERK I's Avatar
donporfi,
Perfect! Thanks. Gotta love this site. So much knowledge and so much help!
Dave
Old 05-24-2005, 10:15 AM
