How To Reduce Height Of 3.2L Motor?
I have a weird question.
Suppose you had a 3.2L motor and wanted to reduce the height of the motor (measured from crankshaft to the top of the AFM unit) by about 6 inches. Could you simply shorten the intake manifold runners, by cutting out a section and then welding the runners back together? Would the reduced height mess up any other components? How would the shorter runners affect the motor's performance?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
plastic intake...
74 911s neverending story. two feet and a jetta for now. |
You mean from a 3.6L? Would it fit and wouldn't you be messing with Varioram and so on?
Suppose you also need to pass California smog. Would a smog center pass a 3.2L with a plastic manifold?
Information Junky
Tonys EFI kit seems to take a lot of height out. IIRC
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Us a non-Vram plastic intake?
What are you trying to do, fit this in a bus?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
6 inches is a lot to cut out of that intake! Just a bit of info for you longer runners tend to make more torque and shorter runners tend to have more top end hp. The plastic 964 intake is not much shorter if any compared to the 3.2...I will have to measure. You would have to get adapter plates made or go with an injector block like mine to adapt the bolt pattern.
Eric Hood |
how about side draft webers on angled manifolds?
don't laugh - a guy i know who likes webers (has quad downdrafts on his morgan plus 8) has just fitted quad side drafts to his 928 in a similar way and reckons they work great.
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
Did Weber make any side-draft 3-bbl's???
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
fitting Webers sounds agricultural to me nowadays
Rich ![]() '86 coupe "there you are" |
Gon fix it with me hammer
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
that would be the Shiznit. anythizle ezle, wozzle bezle underachivizle. or somethin
Ok, Stijn, you win the award for the FUNNIEST comment of the month of May! Ha ha ha !
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
This looks like a 2.7L or a 3.0L
http://volksweb.relitech.com/porsche6.htm One concern with this engine conversion is the height of the Porsche engine versus the VW engine. To clear the taller Porsche engine, the engine hatch needs a raised portion added so that the engine cover can close. Luckily, the area that needs to be taller is all within the bounds of the engine hatch, so only the hatch itself needs to be modified, not the sheet metal of the van per se.
i get one in every 1000 something posts right... please bear with me for the other 999
3 restos WIP = psycho
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
likes to left foot brake.
Saw this one for sale...
Licensed User
The Subaru engine fits in there perfectly.
