jyl jyl is online now
jyl's Avatar
How To Reduce Height Of 3.2L Motor?
I have a weird question.
Suppose you had a 3.2L motor and wanted to reduce the height of the motor (measured from crankshaft to the top of the AFM unit) by about 6 inches.
Could you simply shorten the intake manifold runners, by cutting out a section and then welding the runners back together?
Would the reduced height mess up any other components? How would the shorter runners affect the motor's performance?
Old 05-25-2005, 08:54 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
plastic intake...
74 911s neverending story. two feet and a jetta for now.
Old 05-25-2005, 08:56 PM
jyl's Avatar
You mean from a 3.6L? Would it fit and wouldn't you be messing with Varioram and so on?
Suppose you also need to pass California smog. Would a smog center pass a 3.2L with a plastic manifold?
Old 05-25-2005, 09:01 PM
Information Junky
island911's Avatar
Tonys EFI kit seems to take a lot of height out. IIRC
Old 05-25-2005, 09:13 PM
Us a non-Vram plastic intake?
What are you trying to do, fit this in a bus?
Old 05-25-2005, 09:21 PM
6 inches is a lot to cut out of that intake! Just a bit of info for you longer runners tend to make more torque and shorter runners tend to have more top end hp. The plastic 964 intake is not much shorter if any compared to the 3.2...I will have to measure. You would have to get adapter plates made or go with an injector block like mine to adapt the bolt pattern.
Eric Hood
Old 05-25-2005, 09:40 PM
how about side draft webers on angled manifolds?
don't laugh - a guy i know who likes webers (has quad downdrafts on his morgan plus 8) has just fitted quad side drafts to his 928 in a similar way and reckons they work great.
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 05-25-2005, 09:46 PM
jluetjen's Avatar
Did Weber make any side-draft 3-bbl's???
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 05-26-2005, 03:44 AM
dickster's Avatar
fitting Webers sounds agricultural to me nowadays
Rich
'86 coupe
"there you are"
Old 05-26-2005, 04:40 AM
Gon fix it with me hammer
svandamme's Avatar
the only ones i 've ever seen are 2 barrels
Stijn Vandamme
BIMDIESELBMW116D2019
Old 05-26-2005, 04:46 AM
jyl's Avatar
Well, I am shopping for a Vanagon . . .
Old 05-26-2005, 05:41 AM
svandamme's Avatar
i say , raise the floor , see through , some neon lights, a little water fall, 22 inch gionvanni's and a 40" plasma
that would be the Shiznit.
anythizle ezle, wozzle bezle underachivizle.
or somethin
Stijn Vandamme
Old 05-26-2005, 06:00 AM
304065's Avatar
Ok, Stijn, you win the award for the FUNNIEST comment of the month of May! Ha ha ha !
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-26-2005, 06:10 AM
This looks like a 2.7L or a 3.0L
http://volksweb.relitech.com/porsche6.htm
One concern with this engine conversion is the height of the Porsche engine versus the VW engine. To clear the taller Porsche engine, the engine hatch needs a raised portion added so that the engine cover can close. Luckily, the area that needs to be taller is all within the bounds of the engine hatch, so only the hatch itself needs to be modified, not the sheet metal of the van per se.
Old 05-26-2005, 06:23 AM
svandamme's Avatar
i get one in every 1000 something posts right...
please bear with me for the other 999
Stijn Vandamme
Old 05-26-2005, 06:32 AM
jyl's Avatar
Which seems like it would mess up the lower bunk.
Old 05-26-2005, 11:50 AM
3 restos WIP = psycho
kenikh's Avatar
Yup; checkitout...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-26-2005, 11:57 AM
ted ted is online now
likes to left foot brake.
ted's Avatar
If it was a Diesel Vanagon with 3.2 would it need a smog test?
Saw this one for sale...
Old 05-26-2005, 02:11 PM
Check this one out:
http://home.arcor.de/becks/pics/pclaer.htm
Old 05-29-2005, 08:47 PM
Licensed User
Shuie's Avatar
The Subaru engine fits in there perfectly.
Old 05-29-2005, 08:52 PM
