Sometime back, I removed the rear anti-sway bar and associated fittings and drove the car around town. The clunk remained.
Old 11-07-2005, 12:03 PM
By the way, my problem is on a 1973 - 911T.
Old 11-07-2005, 12:07 PM
Jon Merck's Avatar
Randy, Any updates to this thread? Did you solve the problem? I am chasing a similar one...
Jon
Old 02-26-2006, 09:55 AM
Semper drive!
rcecale's Avatar
WOW! I haven't been back in this thread for a while.
Unfortunately, I don't really have any progress to report. Since my last post I have replaced the axles, thinking maybe one or more of the CV's were bad. This seemed to resolve the clunking initially, but it returned in almost no time.
I've also replaced the engine and transmission mounts, suspecting one or more of them to be the culprit...no joy. Clunking still happens.
Seeing Warrens post, I'm reminded that someone once posted hearing a similar clunk. They ended up installing some heavy duty foam padding around their sway bar, where it passes across the transmission crosmember. This apparently did the trickk for them...the sway bar was bumping the crossmember.
I think I may give fmarin's idea a try and remove the sway bar to see if this does it for me. It's worth a try.
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 02-26-2006, 10:06 AM
Jon Merck's Avatar
Thanks, Getting ready to put mine on stands today and have a look see.
Jon
Old 02-26-2006, 10:17 AM
Hey. I think my problem is solved. Bad wheel bearing. Nothing more, nothing less. $45 for the bearing. Another $25 to fabricate a puller. The bearing came out quite easily as it was a cold day (so the bearing was cold) and I heated the outside of the axle control arm with a propane torch. Hot to the touch, but not burning hot.
Interesting that the bearing made no noise when the wheel was rotated; even listening with a stethoscope.
Here's something I found out. All the Porsche manuals give a torque spec of 34 ft-lb for the bearing cap bolts. Turns out that this spec applies to the 10 mm bolts used on most models. The bolts on my 73T are 8 mm. My mechanic friends say an 8 mm will strip or twist off at this torque. The correct torque for a standard 8 mm bolt should be about 18 ft-lb.
Old 02-26-2006, 07:42 PM
Air Medal or two
afterburn 549's Avatar
Been watching from a distance, as I have the same problem......so the wheel bearing really did it for ya ?? !! that would make my day too!!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 02-26-2006, 08:22 PM
well it sounds like it's going to be a wheel bearing party this weekend... i've been chasing the same problem on my car for years. i was convinced it was the top of the shock mounts moving. same issue, as the noise would arise after a right to left turn transition. time to get on it.
thank you
matt
Matt
72 911T Targa - Sold
Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat.
Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!!
Old 09-29-2006, 09:15 AM
