Question strange engine problem
hello , can anyone help out ?
3.2 86 engine does strange things :
when cold and idling , the engine is going up and down from 0 RPM to 2000 RPM and eventualy stops running.
when I take the oil filling cap of , the engine is running perfect !
when hot, engine is idling on +/- 1000 RPM and no possibility to lower down , or same strange thing occurs .
somebody had the same problem ?
what to do ?
any advise is welcome !
thanks
Old 06-21-2005, 10:04 AM
buster73's Avatar
When you remove the oil filler cap the mixture will lean out. Sounds your injection setup might be off. Try a search on this issue in this forum.
Regards,
Guenter
73.5 911T, mod
Old 06-21-2005, 10:23 AM
thanks buster73
i've done that, but can not realy find the cause , or the way to fix it.
seems that removing the cap leans out the mixure, but what to
replace ?
car has just got his big maintenance job , and before it did not suffer of this. before the engine was getting a lot of air through false places.
or is putting a K&N airfilter on the cap a "allowed" solution ?
Old 06-21-2005, 10:51 AM
PorscheG's Avatar
Disconnect your O2 sensor, and see if that makes any difference.
It should richen up the mixture and settle things down. You may have a bad O2 sensor that sends false signals to the DME, which in turn will adjust the mixture to compensate.
86 - 911 Carrera 3.2
Old 06-21-2005, 11:04 AM
buster73's Avatar
Take it back to where you had the maintenance job done and have them check the mixture. probably they sealed off some air leaks without re-adjusting the mixture. Hopefuly it is just an adjustment and no hardware issue.
Regards,
Guenter
73.5 911T, mod
Old 06-21-2005, 12:55 PM
yep , will do that (taking back to shop)
I hope they will find the problem soon , did not hear a solution so far from them
thanks for the reply's !
bye bye
Old 06-22-2005, 03:21 AM
