hello , can anyone help out ?
3.2 86 engine does strange things : when cold and idling , the engine is going up and down from 0 RPM to 2000 RPM and eventualy stops running. when I take the oil filling cap of , the engine is running perfect ! when hot, engine is idling on +/- 1000 RPM and no possibility to lower down , or same strange thing occurs . somebody had the same problem ? what to do ? any advise is welcome ! thanks |
When you remove the oil filler cap the mixture will lean out. Sounds your injection setup might be off. Try a search on this issue in this forum.
Regards, Guenter 73.5 911T, mod |
thanks buster73
i've done that, but can not realy find the cause , or the way to fix it. seems that removing the cap leans out the mixure, but what to replace ? car has just got his big maintenance job , and before it did not suffer of this. before the engine was getting a lot of air through false places. or is putting a K&N airfilter on the cap a "allowed" solution ? |
Disconnect your O2 sensor, and see if that makes any difference.
It should richen up the mixture and settle things down. You may have a bad O2 sensor that sends false signals to the DME, which in turn will adjust the mixture to compensate.
86 - 911 Carrera 3.2 |
Take it back to where you had the maintenance job done and have them check the mixture. probably they sealed off some air leaks without re-adjusting the mixture. Hopefuly it is just an adjustment and no hardware issue.
yep , will do that (taking back to shop)
I hope they will find the problem soon , did not hear a solution so far from them thanks for the reply's ! bye bye |
