Also, the switches can go bad, and not "return to center" over time. I had to replace a driver-side motor in my `86 (year they changed BTW) due to that. Also, if you are thinking about the conversion, remember to factor in new door panels (or at least having your existing ones re-covered) if you want it to look right.
Thanks Eric,
Already have the new door panels. Just need to get some manual parts.
Andrew Gruppe B #055 78 911SC 74 914 2.0 02 C230K Kompressor 73 VW Beetle AutoStick 02 F250 4X4 (Parts Hauler) 03 Kia Sorento (Wife's DD) |
who is going to perform the public service of weighing & posting the results??
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I thought about doing this same thing. I have had problems with the switch sticking. I also have had to replace the weatherstrip on the outside and the door latch connector. The only advantage to electric windows is being able to lower the passenger side window without stretching across the car.
I was told that this is very expensive to switch. I guess used parts would help but still over $100 per side. Tell me how it turns out. I think you could save about 5-6 lbs per side. |
I'll weigh the regulators when I take them out guys so you know.
thanks for the input..now I'm really wondering if I want to upgrade at all.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
We are gonna need some pics here
This is another mod on my list of things to do....Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Did anyone end up coming up with an overall power to manual conversion solution?
Thanks Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52 |
Troll Hunter
I've got manual windows with the original crank handles. Never had a problem and I wouldn't dream of going to power.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
Eng-o-neer
Hm. Seems like it'd be easier to rewire it with standard components.
Standard automotive relays are $2 and last forever. Standard two-position momentary rocker switches are $1 and last forever. A pair discretely placed in the dash panel and you'd never have to miss an opportunity to yell at someone on the passenger side... Just realized this was a 12-year-old thread brought to life. Last edited by Tremelune; 03-22-2017 at 03:17 PM.. |
disband
I was thrilled when i met my new to me 75S last fall & it having both manny windows & a factory sunroof delete. I have noticed the cranks that appear to have come with what look to be relatively new RS door panels are weak as hell. worst thing is the driver side crank rubbed on the otherwise pristine panel and has scuffed the crap out of the vinyl cover in an 7" circle. since i only drove the car home before dropping & rebuilding the motor window cranks are way down on my list....
i considered the backdate on my SC with power windows and it seemed expensive for minor gain.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Long time ago. I don't remember it being that difficult. Other than the usual, getting the regulator out of the door.
DELETE : Power Windows ?? WTB pair manual window regulators
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor |
I just did this in under 3 hours, removed all wiring also uncut, all the way back to the fuse box. Installed manual tracks, and obviously you will need new door panels as you will have different holes for crank vs switches.
Any diy pics on the conversion?
Is the weight saving worth it? Anyone know the weight saving going from electric to manual?
I thought about doing this but when buckled into my Recaro Pole Positions I can't reach the passenger side door so Manual seems like a bad idea in my non-AC hotrod that I usually drive alone in.
Cheers, Chris 1986 951 SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Eng-o-neer
Nobody seems to have an exact number, but we're talking about less than ten pounds between the axles at ass-height.
Just 10 lbs seems hardly worth the effort for me.
1984 Cabrio - Long Term Project
Did it a while ago, see post #50. Did it more for simplification and reliability purposes. |
