andycook's Avatar
Power Window Delete
I want to do away with the power windows in my SC and go to manual. Is it as simple as just changing over to manual regulators with cranks?
How hard is it to get the power regulators out of the door? Is there a hole big enough to remove them?
Andrew
Gruppe B #055
78 911SC
74 914 2.0
02 C230K Kompressor
73 VW Beetle AutoStick
02 F250 4X4 (Parts Hauler)
03 Kia Sorento (Wife's DD)
Old 06-23-2005, 06:59 AM
RETIRED
Joe Bob's Avatar
Well...ya gotta remove the door panels...lots of screws. Do you have a Bentley manual?
2012 ML350 3.0 Turbo Diesel
Old 06-23-2005, 07:50 AM
andycook's Avatar
Mike, No I do not have the Bentley Manual. I realize I have to take the door panels off. I was just wondering if there were design deifferences in the doors that had PW versus manual. I don't want to have to cut the interior door to remove the power window motors.
Andrew
Gruppe B #055
78 911SC
74 914 2.0
02 C230K Kompressor
Old 06-23-2005, 07:54 AM
RETIRED
Joe Bob's Avatar
AFIK...you don't. "I" would call Parts Heaven or dC Automotive and see if the have complete doors with cranks and ask them to take a pic of the guts. Then pull the panel and compare.
You may find that buying two used doors with crank assemblies is the easiest. Not to expensive last I heard.
Old 06-23-2005, 08:02 AM
andycook's Avatar
Thanks Mike. I'll check into it.
Andrew
Gruppe B #055
78 911SC
74 914 2.0
02 C230K Kompressor
Old 06-23-2005, 08:16 AM
Sameer's Avatar
How much weight can one safe by removing the power windows?
Speed Yellow 911 Ruf BTR Conversion
PCS Membership No: 266
Rennlist Membership No: 050315-5911
Ebony Black 2004 Jaguar XJ6
Titanium Grey 2003 Ford Focus
Old 06-23-2005, 08:39 AM
andycook's Avatar
Sameer, not sure if that was a directed or rhetorical question. I am not doing it for wieght purposes (that's what I tell myself), I am doing it to eliminate the electrical part. I popped a relay, and it pi**ed me off enough to change them out. I know, $20 relay or $100 change over. I figure it will be one less thing to break.
Andrew
Gruppe B #055
78 911SC
74 914 2.0
02 C230K Kompressor
Old 06-23-2005, 08:49 AM
I did the same thing for the same reason. The less electrical, the better.
Old 06-23-2005, 10:08 AM
MAGA
Tim Hancock's Avatar
David, what do you want for your power window set-up?
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 06-23-2005, 10:41 AM
Sorry Tim, all gone.
If you already have manual, why would you do to power?
Old 06-23-2005, 10:45 AM
Information Junky
island911's Avatar
Originally posted by andycook
. .. I figure it will be one less thing to break.
I've had MANY more problems with things breaking on manuals, than with electric.
Those damn window crank handles are generally POS. (always breaking) Though, I have no experience with OE 911 cranks. Maybe, if you get an OE crank it will last a while.
. . maybe even half as long as a power motor.
Old 06-23-2005, 10:54 AM
Eliminates wires to chase though.
My power windows were so unpredictable, I am hoping this will relieve any more window stuck down surprises. Replacement parts aren't cheap either.
I guess some would say weight is a plus too
We'll see.
Old 06-23-2005, 11:00 AM
Information Junky
island911's Avatar
Addendum: Pelican has the rollers .. .about 30 bucks. (replaceable knobs; thats a plus. . .. they are likely pretty stout.)
Let us know how it goes.
Old 06-23-2005, 11:08 AM
well, how much weight are you removing when you make such a change?
carrue529
1987 911 Carrera
S.Wong chip|ElginCams|GT3 oil pump|short gearing|Guard TB-Diff|22/29 Hollow T-Bars|monobloc calipers|Bilstein HD/Sport|Turbo tie rods|Strut brace|CobraMonza II seats|7, 9 Fuchs|Elephant polybronze bearings F/R|Wevo eng mounts|bypass cat pipe|M&K muffler
Old 06-23-2005, 11:22 AM
'74-'79 & '80-'89 regulators and window steel mounting channel are different. The '80-'89 window lifters/regulators were up-graded a few times requiring different mounting hole positions. New regulators are about $150ea. '74-'79 may have the soft metal regulator pivot pins that can be up-graded to a harder pivot.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-23-2005, 11:39 AM
I replaced my driver side manual regulator and "upgraded" to the 80-89 style. Aside from the hassle of getting the regulator in and out the small opening in the door it wasn't too bad. I did have to drill a new hole in order to mount the newer part, but it was pretty straightforward.
Old 06-23-2005, 11:50 AM
Funny, I bought all the old style pieces to go from manual to power on my 78. Most of it looks like crap but thats another story. I'm going to need to replace the door panels if and when I do the conversion to power which will mean I will have to make a commitment and live with it. I think the only thing that has stopped me from moving forward is questioning how reliable the power windows have been for you guys. My car is a garage queen. I suspect that cars that live outside might have more issues with the power windows failing. So, what is the weak link here? The hardware, the harness -relay-fuse, the switches or motors? I have to admit my old cranks have served me well for 27 years.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 06-23-2005, 12:04 PM
andycook's Avatar
Ron,
I cannot attest to any specific weak link in the power window system. I am just more confortable with the manual option myself. I tried to convince mysefl otherwise, heck, I just bought three brand new switches from our host. I am not good at eletcrical, therefore, I just want to go back to old technolgy that I can work on. (same thign with the upcoming CIS delete)
Thank you all for your input and comments. That is why this board is so great. I will look for the parts I need. If anyone needs any electric window parts. let me know.
Andrew
Gruppe B #055
78 911SC
74 914 2.0
02 C230K Kompressor
Old 06-23-2005, 12:09 PM
only imo
- basically the new power window wiring sucks. I'd run in-door relays
- old soft regulator pivots
- old power window sw's do toast interior sw contacts
- old window frame mouldings degrades
- improper window frame alignment tensioning the glass up&down movement.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-23-2005, 12:12 PM
Ron,
Island mentioned the manual crank handles being a weak link. There was a thread a long way back about many various strong crank handles available that will fit.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-23-2005, 12:21 PM
