Senior Member
Tim,
Did you have any trouble welding onto the old muffler? I have heard from some guys that the lead on the inside can make it difficult to weld but had not tried.
Joe A
Old 01-29-2006, 03:09 AM
Originally posted by Joeaksa
Tim,
Joe A
The only trouble I has was that the steel was particularly thin where the PS outlet is placed. Have to go slow.
Warren & Ron, may you rest in Peace.
Old 01-29-2006, 06:06 AM
MAGA
Tim Hancock's Avatar
It was not too difficult Joe (easier than old contaminated aircraft exhaust stacks, harder than fresh .035" walled 4130 tubing). I also tig welded a few pinholes in other places on the muff and on a few of these, the thin outer wall would burn away easily exposing a larger hole to fill. One just needs to make sure to use standard practices of dealing with welding thin stuff. A newbie tig welder might have problems, but any tig welder that has experience with welding thin stuff will not have any problems.
I was shocked that my '79 SC still had it's original muffler (it was date marked 1978!). How many other brands of cars still have a relatively solid muffler usable muffler after 20-30 years of use!?
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 01-29-2006, 06:20 AM
MFORCE
JoeyJoeJoe's Avatar
That sounds like a great upgrade, but what about performance? Any difference?
1985 3.2 Carrera Turbo Targa
Old 04-16-2007, 11:51 AM
MAGA
I did some timed 2nd gear roll on before and after times on a similar weather condition day and got basically identical stop watch readings.
This is an old post, but I still am using this muffler (usually with the second outlet uncapped). I still will probably buy a M&K eventually, as this muffler mod sounds a bit too "V8 musclecar-ish" to me. I like it better than stock, but Ben's M&K has a more appropriate sports car sound to me.
0% Liberal
Old 04-16-2007, 12:55 PM
MFORCE
JoeyJoeJoe's Avatar
ya.... I am thinking cat bypass and M&K plus SW chip
thanks for the info
Old 04-16-2007, 12:59 PM
khamul02's Avatar
Has anyone else tried this mod? I have a cat bypass and am thinking about trying it but I'm worried about it being too loud or sounding "no so good".
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 08-22-2007, 06:46 PM
lespaul's Avatar
I have seen several similar threads about this mod. I may be interested in this. Does anyone have any recent experience/tips on this modification.
In particular, does anyone have a sound clip of their exhaust using this mod?
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 12-09-2014, 08:44 AM
