kenrinc's Avatar
Bug motor in 912
I have need to get a junker 912 running temporarily and since I have a bug motor that is in working condition I thought I'd shove it in there for a few weeks until I can properly finish the job. Anybody have experience on doing this? It can't be that difficult. I'm looking for specifics on what trannies would work as well as connections.
Ken-
Old 06-27-2005, 04:19 PM
scottb's Avatar
Shouldn't this question be posted in the 912 forum?
http://forums.pelicanparts.com/porsche-912-technical-forum/
1984 Targa
Old 06-27-2005, 05:36 PM
dimps8's Avatar
Ken the Pelican 912 board is pretty dead. Try here instead...http://www.912bbs.org/index.php under the 912 help section.....Oh be prepared to cop sum flack over the bug motor, you run the risk of upsetting the porsche gods. Not a wise move.
Damon Harris
66 912 coupe
Old 06-27-2005, 05:41 PM
Paper Member
You'll have to attach a rear mount to the bug engine somehow. They just sorta hung off the transaxle I think but you couldn't do that in the 912.
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 06-27-2005, 05:55 PM
RETIRED
Joe Bob's Avatar
Depends on the year of the motor and the 912 transaxle. They make 180 and 200mm models.
Call Kennedy Engineered Products and tell them what you have. If the years are compatible they will tell ya or supply the required conversion pieces.
2012 ML350 3.0 Turbo Diesel
Old 06-27-2005, 06:04 PM
atlporsche's Avatar
I'll back you up...a TIV is cool.
I'm the one they really hate...I've got subaru power.
sjd
Porsche sold, moving back to muscle cars for a bit.
Old 06-27-2005, 06:26 PM
Location: the bluest city in the bluest county in the bluest state by the bluest ocean...did I mention the blue skies???
I think Harry Pellow coverd this pretty well in one of his books...not sure which one though...sorry.
Greg....PCA, 356 Registry, 912 Registry
1977 911S Targa with 3.2...1960 T-5 coupe
1968 912 coupe, that's 32 P-cars, so far...
1990 Chevy 4x4 2500 pickup (with 255K & still rockin')
Old 06-27-2005, 06:56 PM
RETIRED
Joe Bob's Avatar
sjd
I did a TIV in the 356....was more accepted than the 6 conversion....
BTW...a TIV in a 912 is a an easy install.
Old 06-27-2005, 06:58 PM
DavidI's Avatar
I used to have a 912 with an 1835 dual port webers on it. There is a conversion kit and a Kennedy clutch was used. The guy who did the conversion for me (Carl Monroe of Azusa, CA) has passed away and I sold the car, so I do not have any resource for details. The VW engine used a 912 motor mount which was slightly modified. An electric fuel pump was used with a pressure regulator as well. I'll see if I can find my old receipts from 15 years ago.
You can build a monster engine for an inexpensive price going VW.
Good luck, David
I did a quick search and found a link 912 VW Conversion
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 06-27-2005, 09:28 PM
gerard vaglio's Avatar
Call Devin at HiTecAuto.com in San Rafael at 415-258-9619
They rebuild 912 engines on a regular basis, sometimes they rebuild 912s using VW engines when customers want to save money and increase output.
I'm sure they could tell you which VW engine is used.
Old 06-27-2005, 09:45 PM
atlporsche's Avatar
check the renegade section of the 912bbs. there's lots of info there, as one of the guys just did a Jake Raby built motor in his ride.
sjd
Old 06-28-2005, 04:33 AM
kenrinc's Avatar
Thanks for the info guys. I already know about the flack from the purists. I give it on the 911 side but it's all good. This isn't a permanent conversion, I just need it to get the car going for awhile.
Interestingly enough the car has been modified to fit a 911 motor so it's already "hacked" according to the purists. I can handle manufacturing a mount for the dub motor.
Ken-
Old 06-28-2005, 07:41 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
It can be done. You'll need to do a little research as to how to make the flywheel/clutch work, as well as fabricate a mount for the engine.
A Type 4 would be better though.. More power, less fabrication
Old 06-28-2005, 07:43 AM
