Angry 911SC Starting problem!
My 911SC -80 did run perfect yesterday and on the evening I parked it in the garage.
This morning I sense some fuel smell outside the car (but the garage is shared with many other cars so I dont know if it's coming from mine) and now it does not run.
The car cranks and fires and then instantly dies. Tried this 4 times with exactly the same results, then decided to take the train before I will run the battery flat.
I have checked the board but nothing I read fits into my problem.
What might be wrong with it!?!?
Old 06-28-2005, 11:07 AM
911mot's Avatar
It could be fuel pump relay. Run a live direct to the pump fuse and see if it runs like that. If it does check all fuse and relay connections for corrosion and then try a new relay.
good luck
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 06-28-2005, 11:18 AM
fuel leaking into cumbustion chamber??
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Early_S_Man's Avatar
If it tries to fire while starter is turning, but dies when ignition switch is released to 'run' position ... and, if your car has a factory alarm with keyed switch in the driver's door, then the alarm control module is highly suspect! There is a well-documented [in factory service manual]failure mode of the alarm module that disables the car from being started!!!
Please read the following thread:
'82 SC Won't run
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-28-2005, 12:12 PM
Angry Found the reason...
When I moved the car (by hand) to get better light I found the reason. Someone had broken into and emptied it totally on gas!!!
Thats why I smelled gas around the car!
Put some 10 liter of petrol in it and now it spins again.
The leasson learnt here is that the fuel-meter does not update itself if there is no gas in the tank. Mine was showing 1/3 of gas until it had run for some minutes then it dropped down and the red light came on.
Going to the insurance company and local Porsche shop tomorrow.
Old 06-30-2005, 11:17 AM
