cjr1's Avatar
Angry How to remove Head temp sensor?????
Rebuilding my 3.2 with 156,000 miles.During teardown,got to pulling sensors,switches,etc. from engine.Head temp. sensor is installed into pocket on side of head & has attached wire on sensor.Because of wire,can't use regular deep well socket,b/c of clearance around sensor can't get boxend wrench or open end on it either Sent heads & cams to EBS with sensor still in.Apparently,they had issue getting it out also.Ruined sensor in process.Oh Well,add $59 to the tab.What is correct tool for this??
Best as I could judge,something like a o2 sensor socket w/ a slot cut out would appear to work but couldn't find one in correct size which is 14mm??Do I need to sacrifice a 14mm deepwell to the cause or anyone know where to find one.Have looked around some,Craftsman,Snap-On,McMaster-Carr etc....No Luck
Anyone?????
Just talked to Don @ EBS.....all new valves needed....so much for the budget rebuild
"If you think it's gonna cost $1000, ya better budget for $2000."
Chris
85 Carrera 3.2(Back on the road after rebuild)
02 Trans Am WS6
95 Eagle Talon
98 Bravada(sold)
07 G5
Old 06-30-2005, 05:50 AM
These can probably be purchased from Snap-On, Matco, etc., but for the $$ difference and time expended, I'd suggest a Craftsman 14mm, 6 pt. deep sockect and cut a slot up the side for this project. We use this setup at the shop and it works just fine.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 06-30-2005, 06:07 AM
cjr1's Avatar
Did check the snap-on catalog @ work.Didn't see it in there.Thats ok.Found an older 14mm socket to modify.Thanks for the response.
Chris
Chris
02 Trans Am WS6
95 Eagle Talon
98 Bravada(sold)
07 G5
Old 06-30-2005, 06:26 AM
kqw kqw is offline
I purchased mine from Snap-On....
Here's a pic.
The Fox
Carrera
Old 06-30-2005, 06:47 AM
trak ratt's Avatar
Two local shops also recommend this method to me also. Easier to accomplish with cut off wheel than hack saw!
Old 06-30-2005, 06:54 AM
cjr1's Avatar
Thanks for the info everyone!Will be ready when heads return!
Chris
Chris
02 Trans Am WS6
95 Eagle Talon
98 Bravada(sold)
07 G5
Old 06-30-2005, 07:03 AM
kqw kqw is offline
Snap-On part number:
FRXM14
The Fox
Carrera
Old 06-30-2005, 07:05 AM
Send a message via AIM to ajackson
If you are going to replace the sensor anyway, you can just cut the wire and use a normal socket.
Alan Jackson
77 911S 3.2
Old 06-30-2005, 08:45 AM
Alan is right.
Chop wires and use a socket. I did.
Ned
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 06-30-2005, 08:54 AM
Jeff Alton's Avatar
I just cut a box end wrench, 14 mm or if you do not have metric, use a 9/16. Cut a slot into the box end to pass the wire through. Works great.
Jeff
www.turn3autosport.com
Old 06-30-2005, 09:47 AM
I'm With CATCA...
I used a 6 point 9/16" deep socket and chop sawed a slot in it stopping just prior to the square drive...
75 911S Coupe 3.4 Twin Plug - ITB - MegaSquirt
84 Carrera Coupe M491
Old 06-30-2005, 10:02 AM
all the heads have a sensor hole, so you can use any of them as #3. be careful not to tighten the new one too much. they snap off. then you have to get the threaded part out again.
206 637 4071
Old 06-30-2005, 11:17 AM
