915 trans overflow?
Just rebuilt my 915 with new 2-5th gear & added Wevo shift gate.
At Mosport this past week I had at least a pint of trans fluid come out of the overflow tube. I suspected that it was because the car was thrown around allot in some corners. I cleaned it all up and went for a pretty ride on the street, only got stopped once, I guess it was the numbers and lack of real muffler that gave that away
After that I had a smaller amount come out, but definitely from the tube.
Is it possible that the the trans was simply overfilled? Or is the fluid getting so hot that it's coming out?
It was not replaced with swepco.
Never experienced this issue before. But I have never had the trans apart or filled the fluid.
Any thoughts?
Old 07-05-2005, 11:22 AM
trak ratt's Avatar
When in the car, and reasonably level the fluid is typically filled through the side filler hole until it runs out. This insures the correct amount. Did you fill the trans beyond this point? I’ve run Swepco in 915s and 901s on the track and auto-x filled this way for years without spillage
Old 07-05-2005, 11:31 AM
not sure. It was done at a shop. I assume and agree that should be the only way to fill it.
Assuming that it was overfilled some other way can this overflow happen from heat or another issue? Could they have filled it anyother way?
Old 07-05-2005, 11:39 AM
Chuck Moreland's Avatar
Check that the vent is oriented properly, it should point forward. If pointed wrong, it will do just as you describe.
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-05-2005, 11:50 AM
Thanks chuck
I assume you mean the tube I can see from under the car?
It's straight down now.
If it's not the tube I can see, please point me in the right direction.
John
Got some of your stuff on my ride. Planning a poly-bronze winter project! Thanks
Old 07-05-2005, 12:02 PM
Hi John
No, there is a vent on top above the R&P area right in the center. You can reach up there with your hand and feel the orientation. You can turn it if needed.
Old 07-05-2005, 12:10 PM
tube? there ain't no tube.
206 637 4071
Old 07-05-2005, 12:13 PM
Ok I'll check. Thanks.
Any hints on what it feels like? Or where I can see a digram? Photo?
John:
The tube looks like a braided hose with a clamp holdining it up by the starter. It's got trans fluid dripping out of it after a while
Old 07-05-2005, 12:24 PM
somebody added that hose, it's not stock. the breather fitting is on the top center, above the diff housing, just behind where the bellhousing joins the diff housing. you can feel it and the hole with your hand. hole must face forward.
206 637 4071
Old 07-05-2005, 12:48 PM
Thanks. I'll check tonight
Old 07-05-2005, 12:50 PM
Semper drive!
rcecale's Avatar
As JW stated, "hole must face forward."
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 07-05-2005, 01:26 PM
Thanks! I appreciate the photo
Old 07-05-2005, 01:31 PM
She/Her
BeauBlues's Avatar
Ah, yes the ole breather on the 915. Believe me I learned the hard way that it should point forward. I lowered the engine and trans to figure that out. And all thanks to MM for that since they couldn't figure it out after they had it rebuilt for me.
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 07-05-2005, 02:28 PM
Angry
It looks like I just made this stupid mistake, I got transmission fluid everywhere.
I had just done a rebuild and took the vent out, when I put the vent back in I turned it towards the engine, I guess that wasnt a good idea.
Its fixed now. Vent hole pointed towards the front of the car.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-20-2010, 09:51 PM
