Send a message via AIM to air-cool-me
tell me about the difference between 3.0 and 3.3 turbos.
3.0's have a shorter stroke (70.4mm)?
the use 95mm pistons with 6-5 as opposed to 7-1 comp ratio
do they have the same piston squirter's?
are the upgrade paths relatively the same?(euro exhaust,intercooler,k27)
will the extra .5 a point of CR make a bid difference in the off boost performance?
what else can you tell me about the early 3.0?
thanks
-nick
SWB
Old 07-07-2005, 04:01 PM
3.0s have a higher-capacity fuel distributor. Same upgrade path, starting with removing thermal reactors and installing an intercooler.
Old 07-07-2005, 04:12 PM
then NA's or 3.3's?
SWB
Old 07-07-2005, 04:34 PM
3.0 930 fuel heads flow more than 3.3 930 fuel heads, from what I have read. They can be retrofit to later engines. ImagineAuto also does an upgrade to get higher flow, I believe.
Old 07-07-2005, 04:49 PM
thanks!
SWB
Old 07-07-2005, 06:21 PM
