tell me about the difference between 3.0 and 3.3 turbos.
3.0's have a shorter stroke (70.4mm)?
the use 95mm pistons with 6-5 as opposed to 7-1 comp ratio do they have the same piston squirter's? are the upgrade paths relatively the same?(euro exhaust,intercooler,k27) will the extra .5 a point of CR make a bid difference in the off boost performance? what else can you tell me about the early 3.0? thanks -nick
SWB |
3.0s have a higher-capacity fuel distributor. Same upgrade path, starting with removing thermal reactors and installing an intercooler.
993 |
SWB |
3.0 930 fuel heads flow more than 3.3 930 fuel heads, from what I have read. They can be retrofit to later engines. ImagineAuto also does an upgrade to get higher flow, I believe.
993 |
thanks!
SWB |
