Gumba11's Avatar
Wink Turbo problem solved!!! (Funny)
I finally found the perfect trim for the inducer wheel on my turbo. This should provide enough air!
LOL....................................C
77 930 "P Zilla" 3.2 Litre w / EFI conversion
Old 07-08-2005, 06:20 PM
Paul K's Avatar
So the question I have is...
Polish or powder coat?
Cheers!
Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 07-08-2005, 06:55 PM
Sales Pitch: "It's great for top end power but may have alittle more throttle lag than stock"
Old 07-08-2005, 07:31 PM
Air Medal or two
afterburn 549's Avatar
do you run a internal or external wast gate??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 07-08-2005, 07:47 PM
Formerly bb80sc
Vipergrün's Avatar
I see an E-Ram version in the near future......
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 07-08-2005, 08:49 PM
Automotive Monomaniac
Emission's Avatar
"Once this baby spools up.... HAAAAAAANNNNNNGGGG OOOONNNN!
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 07-08-2005, 09:48 PM
Send a message via Yahoo to Lukesportsman
Can I still use the stock exhaust?
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 07-08-2005, 10:10 PM
That the is the stock turbo that came off one of these (I believe):
Yasin
Old 07-09-2005, 03:57 AM
Wider is Better
wholberg's Avatar
So...what compression rings do you use for 2000 lbs of boost?
Wider is Better
Old 07-09-2005, 06:17 AM
jjwood's Avatar
Yea -- but what about twin turbos?
Jeremy
1971 911 Wide One 2.7
2012 911 Cabriolet
2011 Cayenne S
Old 07-09-2005, 08:34 AM
Unregistered
sammyg2's Avatar
LOL, let me guess. 1st stage impeller off an Elliott or IR Centrifugal compressor, prolly a 3 or 4 stage unit. Used primarily in gas handling and seperation units (CO2, h2, etc).
Yep, I've rebuilt more than my share of those beasts, even spent some time at the factory in Jeanette, Pa.
Scary thing is, they have actually made some much bigger than that.
They have a concrete/steel lined vacuum test chamber where they spin em up for balance, then over speed em to make sure they don't fly apart. The vacuum chamber is almoast as big as my garage.
Old 07-09-2005, 09:08 AM
Emission's Avatar
Is that thing titanium or stainless? Or ceramic? How heavy is it?
Old 07-09-2005, 12:48 PM
I wonder how fast that must spin to generate boost? And how much boost?
Sherwood
Old 07-09-2005, 12:56 PM
Unregistered
sammyg2's Avatar
On one that size is it is prolly limited to 16,000 rpm. the really small ones on the final stages spin as fast as 56,000 rpm.
They have a very large diamter bowl gear that spins at 3600, then the smaller pinion gears run off the bowl gear and spin the impellers.
The rpm of the impellers is determined by the diameter of the pinion gears.
Compression ratio on these things is usually designed for 3:1. So if a 1st stage has a suction pressure of 14.7 psia (atmospheric pressure), the discharge pressure should be around 45 to 50 psia, or 30 to 35 psig. The diameter determines the rate of flow, one that size is prolly on a 80,000 cfm machine. I'd guess the driver is rated at around 3000 hp.
Material of contruction is usually aluminium on the smaller ones and stainless steel alloys on the bigger ones.
The one in the picture prolly weighs close to 100#
Old 07-09-2005, 02:59 PM
Emission's Avatar
Wow. Interesting technical data!
Old 07-09-2005, 03:09 PM
Unregistered
sammyg2's Avatar
Uhhmm, really? I figured I was raining on everyone's parade by trying to be serious when they were cracking jokes
I just couldn't think of anything funny to write
Old 07-09-2005, 04:15 PM
