LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average.
rdane's Avatar
AR Concepts 911R tail light question ?
More than one of us using them. Would other's mind posting their car's? Also what did you use for a seal between the bumper and the car's body? I am looking for a single piece of trim to seal up the rear impact bumper..
Thanks!
These are just the ones I could fine.
I have a gap here I want to get rid of. Do I need to add to the bumper?
Old 07-09-2005, 07:49 PM
Sports Purpose 911 Driver
mjshira's Avatar
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 07-09-2005, 08:29 PM
mjshira's Avatar
Old 07-09-2005, 08:31 PM
Administrator
Jack Olsen's Avatar
The first car pictured (mine) doesn't have the AR Concepts pieces. Mine are one-off's from before AR Concepts was making them.
AR Concepts' pieces have much better fit and finish than mine, but faithful reproductions of the 911 rear bumper still leave a gap below the light assembly. Maybe AR Concepts (or someone) should make a bumper with tighter tolerances than the factory specified?
Old 07-10-2005, 12:06 AM
I don't have seals on mine, and mine has a funky 'ledge' to the left of the leading edge of the light due to excessive bondo in the quarter panel.
Old 07-10-2005, 12:29 AM
randywebb's Avatar
Has anyone ever used body putty to fill in the cracks/lines where the part fits into the body?
I'd like to see what that looks like...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 07-10-2005, 09:44 AM
mjshira's Avatar
no, you don't need a gasket. At least I have not and I have driven mine in rain many times. I am actually replacing a bulb at the moment. Important is to use some silicone to seal things up to keep the water out.
Old 07-10-2005, 10:07 AM
rdane's Avatar
Thanks Jack. I had wondered if it was just mine. I'll give Dave at TRE a call on Monday and see if they have found an answer for the trim seal.
Old 07-10-2005, 03:34 PM
