Send a message via AIM to tony77targa
rear targa window install #%&^*HELP!
I cant get even get the rubber to stay on the glass where the glass would meet the targa bar...the rest of the rubber is on and stayin in place ... do you have to tape this down to get the window in place and then remove the tape? I cant see how its possibe.....
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 07-12-2005, 03:55 AM
abit off center
cgarr's Avatar
These are a bastard!! at least for me. If I was to do mine again I would use something to bond the seal to the glass, a glass shop should have something? My problem was keeping the trim in place while installing it. I have tried tape and it didn’t work worth a *****.
Craig
______________________
Craig
G2Performance
Old 07-12-2005, 05:14 AM
My body guy complained that it was a b!tch too, so don't despair. Have you seen this thread? It might help with the rest of your install.
Neil
'73 911S targa
Old 07-12-2005, 05:18 AM
Craig ... Im gonna try "seal all" its made to glue rubber seals in place then tape it down till its cured ... then start the fun part....
Neil I did see that thread and it starts with "once the seal is in place" I cant even get the eaasy part done!!!!
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 07-12-2005, 05:31 AM
New kid in town
71T Targa's Avatar
It took two glass guys 4 hours to do mine...
I wish I still had 9111113443...
Old 07-12-2005, 06:21 AM
Ok forget the "seal all" another hour and the rubber is still not all the on the glass... the groove for the glass has like two channels in it .. which channel is the glass supposed to go into the innermost channel or outer channel?
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 07-12-2005, 07:22 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
It's not unusuall to tape the seal in place on some windows. You might also try laying the seal in the sun to soften it up just a bit. Glueing the seal onto the glass as you mention would probably work also, just a bit time consuming.
I'm not familiar with EZ St. and Memory lane. Is that anywhere near So Cal?
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 07-12-2005, 07:35 AM
Yes time consuming and very messy... I just tried that method in a small area and found it to be very messy and not much help... I have two channels in the glass groove ... which one does the glass actually supposed to go in ? EZ street and memory lane? Its actually in Holden Maine...BTW do you know Dick Hertz from Holden?
Every rose has its thorn is rather appropo for this thread as I think I just got pricked by the thorn of the 911 targa.....
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 07-12-2005, 07:54 AM
LakeCleElum's Avatar
Holden, Maine aye???? My ex-wife ran off with her dentist boss in 1984. He then relocated from Seattle to Holden...I've been thru Holden a few times; nice area, but I don't stop to get my teeth worked on!!!!!!
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 07-12-2005, 08:03 AM
1.367m later
KevinP73's Avatar
Sorry don't know Dick Hertz from Holden Maine. Might want to ease up on your grip a bit, see if that helps.
As for the glass seal, the glass goes into the uppermost channel. The lower channel is where the flange on the body will set into.
Old 07-12-2005, 08:04 AM
Hey Bob Maybe the dentist/wife thief changed his name when he moved up this way.....
Kevin ... I know which groove the glass goes in but wihin that groove is two channels one a bit deeper than the other
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 07-12-2005, 08:39 AM
1.367m later
KevinP73's Avatar
Top groove. lower groove is for the defroster wires
Old 07-12-2005, 08:47 AM
Thanks Kevin ... so the deeper channel closest to the inside of the car is for the wires and the slightly shallower channel closest to outside the car
is for the glass.... seems logical enough but when things dont go together you must step back and consider the ilogical sometimes......
I just cant believe after doing the front windshield the rear window is so much more difficult.....I WONT GIVE UP!!!!
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 07-12-2005, 10:05 AM
Series900's Avatar
forget the wires.... lost cause! just getting the window in is a chore, Me thinks the factory had a rolling stock of individuals who could stand to put these in for one month, and then gave them 11 months on the riviera for compensation...
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 07-13-2005, 05:46 PM
Kevin Stewart's Avatar
put a string all the way around, put the seal on the chassis, sit window on seal, you have to push the window forward to the front of the car then down, once you get it forward pull the string, when it ready to go down push the string, the glass guys couldnt get mine in, it took me 45 minutes, you may want to get some soap or silicone spray, the window has to go forward then down, Kevin
Old 07-13-2005, 06:06 PM
AAAhhhh yes the ilogical method has shown itself... I just finished instlling the glass when I came in and read your post...I taped the rubber to the glass set the whole thing in place and put a strap accross it with light preassure and removed the tape took up a couple clicks on the strap and began pulling my string If I ever do it again I will try the rubber on the chassis first....
Thanks everyone for all the help!!!!!!!
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 07-14-2005, 11:24 AM
efhughes3's Avatar
Ditto that-two EXPERIENCED guys that the Dallas dealers ALL recommended. I tried THREE glass companies before that-they failed.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-14-2005, 11:31 AM
