Virginia Rocks!
VaSteve's Avatar
Exclamation Urgent Need Help! Shift tube bushing bracket mounting
Is this supposed to install like I have it in the photo, or under the tunnel lip. When I took it apart it was loose on the shift tube so i dodn't take note.
tkanks!!!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 07-16-2005, 09:21 AM
Virginia Rocks!
VaSteve's Avatar
wrong photo...
Old 07-16-2005, 09:23 AM
It should sit on top - as you have it in the photo.
Regards
Hayden
Old 07-16-2005, 09:58 AM
Recreational User
porschenut's Avatar
In my Carrera, it goes UNDER, not on top. I can't imagine the SC was different.
Old 07-16-2005, 10:06 AM
Virginia Rocks!
VaSteve's Avatar
Problem solved. It goes on top. There is a notch in the housing. You can kind of make it out in my photo above.
(I had it in there under the first time, and it bound up. )
Wayne's a liar, this wasn't a 2 wrench job.
Old 07-16-2005, 10:51 AM
