theclaw's Avatar
Quick and dirty a/c question
I'm trying to do a quick and dirty 134a conversion and bought the nipples and a kit from the local PepBoy/AutoZone/Murray's auto store. However the nipples didn't fit. I was told that there is not alot of quesswork to get the hi and lo pressure nipples switched out. Am I missing something?
Jeff
Old 07-16-2005, 09:51 AM
Would the conversion fittings not screw on? Is the High side and Low side fittings the same thread on your R-12 system?
www.exeterautosupply.com
1976 911S Targa
Old 07-16-2005, 10:19 AM
Your instance is not the first time "R-134a conversion kit" high side fittings haven't fit 911 A/C systems. Jim
Old 07-16-2005, 12:37 PM
There are several fittings on the schrader side of the nipples. They have other nipples behind the counter that they can sell you.
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 07-16-2005, 03:29 PM
theclaw's Avatar
The clerks at the first store didn't seem to really get it. There are others around I'll have to try them. Thanks.
It looks like both the H and L pressure taps are the same size, 3/8ths (right?). The kit i picked up actually had three different sizes, H, L and GM (?).
jeff
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 07-16-2005, 03:32 PM
That sounds right be carefull and make sure you don not turn can upside down also three cans should be fine the pressure in 134 is much higher, start with two cans run the car with a/c and then add the 3rd can if needed. You should find an a/c manifold and check you high pressre because it runs much high then r-12.
1986 blk 930
2000 expedition
Old 07-16-2005, 03:39 PM
You do know, you also have to change the compressor oil? Jim
Old 07-16-2005, 04:18 PM
theclaw's Avatar
Yes, thanks. I've read all (well... alot) of your stuff. Good info.
Jeff
Old 07-16-2005, 05:33 PM
