Dwell meter timing light suggestions
Hello Everyone! Newbie here, looking for suggestions on a
decent timing light and Dwell meter to help me with my 76. Mechanically inclined, lacking Porsche wisdom, but learning a little more every thread!
76 911/2.7/SSI/2in 1out/tensioners/Ice Green Targa 01 Suburban 02 Jeep Liberty WillsWings Eagle "As I hug the mountain tops in my hang glider, the only distraction Is looking below at the roads I will hug with my 911 " |
maybe I am using the wrong term for dwell. Allows you to check air fuel mixture?
Gliderguy,
I have the Sears model that Rattlesnak shows, and it works very well for me. I could not live without the dial in feature. If you are still running points, a dwell meter is a good idea. I have, in an emergency, set points using a match cover for thickness, and been spot on when I finally got near my tools. But a dwell meter beats any feeler gauge in my book. Rex
1975 911s 1997 Saab 900s |
I have an older version of the Sears Craftsman at the bottom of Chris' list [a relabeled KAL 4185/Actron CP7519] ... ands it works great for under $100! A PDF-file copy of the user manual is at the link below:
http://www.actron.com/publish/2004/06/07/pdf_english_16182.pdf Actron CP7519 details: http://www.actron.com/product_detail.php?pid=16182 The SunPro/Actron CP7676 Automotive Digital Multimeter includes tach/dwell functions ... works well, and is featured in the Bentley manuals for SC and Carrera. http://www.actron.com/product_detail.php?pid=16291 User manual is here: http://www.actron.com/publish/2005/03/28/pdf_english_16291.pdf
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Gliderguy,
A dwell meter will show how long points are open, and thereby the point gap. Rex
Thanks for the input! What will tell me if my air fuel mix is correct?
gliderguy,
You are referring to the duty cycle though I do not know if this will work on your car. The three-pin test connector is used, at least on mine, when performing the A/F adjustment with this methodology.
Daryl G. 1981 911 SC - sold 06/29/12 |
gliderguy,
If your '76 is stock CIS ... it doesn't have a frequency valve or O2 sensor! That means you don't need to worry about duty cylce or adjustments to the O2 system, an add-on system to SC engines. Your mixture is adjusted with a 3 mm hex key while monitoring the CO output with an exhaust gas analyzer such as the Gunson.
correct no O2 sensor I have the 3mm allen, and contemplating a Gunson. Would to rich a mix possibly cause it not to start?
"After the passing of many moons maybe I will be able to answer some tech questions, right now just a empty spounge soaking it all in!!!"
Designer King
I suppose it's possible, but usually a too lean mixture would be more likely to do it. You should do a search. There is a huge amount of info on CIS starting issues, including air leaks, WUR, AAR, AAV, CSV,check valve, fuel accumulator problems and on and on...
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Dirty points will cause a no start. So will points not opening or closing.
Joe |
