Decal applying question
I am reapplying the black adhesive decals (the same material as the black stoneguard decals on the 76 to 89 turbos)to the clamshell of my 89 speedster (luckily I have 1 set left). The first time I applied these I used windex to position. I have reread the decal posts where people mention using soapy water. Which would work more efficiently?? The first time I did not squeegee right and got bubbles which I have tried pricking with a pin but still is noticeable. Any help greatly appreciated!!
Funnyguy
Old 07-17-2005, 11:43 AM
adomakin's Avatar
all the people that I have seen putting stickers on have used soapy water and a little rubber block to squeeze out the air bubbles. I just had our work trucks sign written and the firm that did the work used the same technique
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 07-17-2005, 02:12 PM
Wavey's Avatar
Don't use Windex - the ammonia is bad for the adhesive. Soapy water is OK but not really necessary unless you're applying something large to a compound-curve surface or to glass, or unless you're really unsure of your ability. If you use it, you only want a few drops of liquid detergent to a quart of water, and you don't want to get any on the top surface of the carrier paper. I own a sign company and we apply 99% of our vinyl dry.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 07-17-2005, 04:14 PM
