Snort, pop, and boom on deceleration w/ SSI's and MB911 muffler
My 87 3.2 w/stock chip, SSI's , and Bens type R 2in/ 2out muffler, seems to snort and pop on deceleration a lot more than the GHL Bypass and single out GHL I had before.
With SSI's and dual out muffler, do I need a Wong chip to correct the fuel mixture? .....or should I be learning how to adjust my AIR/ FUEL Mix?
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted. |
Mine does this too, to a certain extent. I have the exact same exhaust setup, though I do have Steve's chip, too.
With reduced backpressure more unburned air / fuel makes its way into the exhaust system add the more readily available oxygen, you will have a mini explosion in the pipes. Steve Wong has a similar setup on his car and so I bought the programmed chip that he runs on his car. My car idled much smoother and revved much better with his chip. I never dyno'ed, but suspect you'd find more power. I did the 8k DME upgrade, too, which is what Steve recommended. My car had the 2k chip, initially. It is definitely MUCH smoother.
1971 RSR - interpretation |
Recently Disbanded
a fix all would be don't decel, keep your foot in it at all times.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
You must have an air leak somewhere, probably at the SSI/muffler union. Ben's muffler flanges are not always straight. Ask me how I know.
good call zeke. I will snug it up & try
Thanks milt!!!!!!!!!
anyhow typically you need a wong chip for the 3.2 with ssis and those flanges were dead on
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Could it be you are hearing it now and before it was muffled?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Well, maybe before my neighbor could hear it, and now the guy 2 blocks down can hear it fine.
Actually it is almost a backfire sound. Sounds like unburnt fuel & hot exhaust. I do think that it has got increased gurgle frequency as well.
I am running a Borla SS with a Fabspeed cat bypass pipe and a SW chip programmed for that set up. I too, get gurgling and noise, not a back fire, but a lot of rumbling sounds. I asked about it with my mechanic and he said it was the design of the Borla, no baffles, or little baffles or something like that. So, I just enjoy it.
I had thought it was the seals too, but I replaced all of those and it still rumbles..... YMMV -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
I really like the sound the way it is. I just want to be sure I am not f.ing something up.
