Snort, pop, and boom on deceleration w/ SSI's and MB911 muffler
My 87 3.2 w/stock chip, SSI's , and Bens type R 2in/ 2out muffler, seems to snort and pop on deceleration a lot more than the GHL Bypass and single out GHL I had before.
With SSI's and dual out muffler, do I need a Wong chip to correct the fuel mixture? .....or should I be learning how to adjust my AIR/ FUEL Mix?
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 07-21-2005, 05:56 AM
DW SD's Avatar
Mine does this too, to a certain extent. I have the exact same exhaust setup, though I do have Steve's chip, too.
With reduced backpressure more unburned air / fuel makes its way into the exhaust system add the more readily available oxygen, you will have a mini explosion in the pipes.
Steve Wong has a similar setup on his car and so I bought the programmed chip that he runs on his car. My car idled much smoother and revved much better with his chip. I never dyno'ed, but suspect you'd find more power. I did the 8k DME upgrade, too, which is what Steve recommended. My car had the 2k chip, initially. It is definitely MUCH smoother.
1971 RSR - interpretation
Old 07-21-2005, 06:15 AM
More Likeable IRL
juanbenae's Avatar
a fix all would be don't decel, keep your foot in it at all times.
Old 07-21-2005, 06:34 AM
Zeke's Avatar
You must have an air leak somewhere, probably at the SSI/muffler union. Ben's muffler flanges are not always straight. Ask me how I know.
Old 07-21-2005, 07:15 AM
good call zeke. I will snug it up & try
Old 07-21-2005, 07:16 AM
Thanks milt!!!!!!!!!
anyhow typically you need a wong chip for the 3.2 with ssis and those flanges were dead on
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 07-21-2005, 07:29 AM
Elombard's Avatar
Could it be you are hearing it now and before it was muffled?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 07-21-2005, 09:00 AM
Well, maybe before my neighbor could hear it, and now the guy 2 blocks down can hear it fine.
Actually it is almost a backfire sound. Sounds like unburnt fuel & hot exhaust.
I do think that it has got increased gurgle frequency as well.
Old 07-21-2005, 09:13 AM
I am running a Borla SS with a Fabspeed cat bypass pipe and a SW chip programmed for that set up. I too, get gurgling and noise, not a back fire, but a lot of rumbling sounds. I asked about it with my mechanic and he said it was the design of the Borla, no baffles, or little baffles or something like that. So, I just enjoy it.
I had thought it was the seals too, but I replaced all of those and it still rumbles.....
YMMV
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 07-21-2005, 09:48 AM
I really like the sound the way it is. I just want to be sure I am not f.ing something up.
Old 07-21-2005, 10:03 AM
