Adding a wire for a tail light problem
I can not figure out my left rear tail light (not blinker or stop) just a light that goes on when driving at night. Can anyone think of a way for me to run the wire without drilling a hole next to where the left tail light harness goes through the body. I am all set the rest of the way.
Any ideas? Thanks, David |
David,
There should already be a spare wire in the harness to the left rear lamp housing for the 'Euro' rear fog lamp. On early cars it is a White/Green wire behind the dash and folded/taped up ... where the fog lamp switch should go. At the lamp assembly the color changes to Green/White.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks Warren.
Say I can't find itm any other ideas? I have a wire running from the from fuse box to the engine compartment, I just need to get it out to the light in the tail light assembly. David |
Designer King
Can you access any other wires to the assembly? If so. tie or tape another wire or string to it/them, pull it all back to the engine compartment, leaving the pull string exposed out the back. Then tie the new wire on and pull it all back to the light.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
