Short shift install Wow!
I ordered my new factory short shift on Wednesday from PP and had it shipped USPS priority mail ( least expensive ) , so I figured it would get here sometime next week but to my surprise it arrives today . I installed the shift kit along with new bushings and what a difference it makes . You actually feel like you are shifting a modern day car . I highly recommend this upgrade and its pretty straight forward to install .
77S 04 Titan 03 Xterra |
I am considering this for my SC. How long did the install take?
I spent about three hours . If you've been into your shifter before you should be able to do it in less time . While your in there change the 2 bushings also . You won't be sorry for the time and money spent .
Author of "101 Projects"
I recommend this - I have it installed in my own car.
Here's the link to the catalog: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_pedals_pg1.htm#item0 -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Porsche-pa
Where did you get the short shift kit you used? How much was it?
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious), Also rans... '02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7, Donny |
Porsche-pa
I just looked at the PP list of shift kits and there are two? Which one did you use?
Don't forget to do the bushings and coupler while "you are in there"
the Wevo clamp is also advisable.
Re: Short shift install Wow!
Factory Porsche Short Shift Kit, 911 (1972-86) [Photo] C-424-931-00 $189.00
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
I thought the factory SSK was no longer available? Wayne, did you find a stash, or are they back in production? Or, am I confusing it with a gate shift kit?
T.
'73 Targa |
drag racing the short bus
Bill - what is the Wevo clamp? Is it what is described here in this exploded view as the coupler clamp? The clamp is in red.
