Help I need hinge guru's
My hinges ( top of doors ) are very sloppy. I replaced the pins but the hinge that is welded to the door is worn. My car is ready for paint and I need a quick answer so I don't slow down the paint job. Does anybody know the answer ? I tried our host for some form of bushings but they don't carry them. Thanks in advance Steven.
1986 blk 930 2000 expedition 2000 bmw 3 series convertable 1996 Silverton 312 sedan bridge |
Navin Johnson
GT racing makes hinges with bronze bushing which are used to mount their glass/carbon doors.
Maybe you could use these with the stock doors.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I would rather be driving
you should be able have a machine shop make some bushings. Are you sure the pins are not worn and not the hinges?
The upper hinge is not welded. It is riveted to the door. Teh lower hinge is integral to the door frame. The pins can be pressed out and the body side will unbolt. This will allow you to separate the hinges and look for wear. YOu should be able to detect where the wear is by rocking the doors and thus make a decision on where to make changes to correct the slop.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Call Stoddard for the bushings. The pins are much harder than the bushings, so they are not apt to wear. Take them out and check them with a mic.
Thanks Zeke stoddards has them in stock 2.00 each I will have them in 2 days.
Your local dealer should carry the bushings. The bushings will need to be reamed and filed to fit once installed. You will need an 8mm (if I remember correctly) ream to do the job correctly.
Dean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
(OK, we have had this discussion many times before. So don't everyone talk bout dealers) Stoddards is special. Owned by the factory, I'm told, and keep a lot of hard to find parts. |
This is the first time I talked to a dealer and they were nice, my local dealer changed the belts in my 944 five miles later I eat my top end they say not there fault.My local dealer sucks . The Stoddard dealer was veryhelpfull for a two dollar part not bad.Thanks again
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
