Help I need hinge guru's
My hinges ( top of doors ) are very sloppy. I replaced the pins but the hinge that is welded to the door is worn. My car is ready for paint and I need a quick answer so I don't slow down the paint job. Does anybody know the answer ? I tried our host for some form of bushings but they don't carry them. Thanks in advance Steven.
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 07-25-2005, 02:26 PM
Navin Johnson
TimT's Avatar
GT racing makes hinges with bronze bushing which are used to mount their glass/carbon doors.
Maybe you could use these with the stock doors.
'69 911 GT-5
'75 914 GT-3
and others
Old 07-25-2005, 02:42 PM
I would rather be driving
jpnovak's Avatar
you should be able have a machine shop make some bushings. Are you sure the pins are not worn and not the hinges?
The upper hinge is not welded. It is riveted to the door. Teh lower hinge is integral to the door frame. The pins can be pressed out and the body side will unbolt. This will allow you to separate the hinges and look for wear.
YOu should be able to detect where the wear is by rocking the doors and thus make a decision on where to make changes to correct the slop.
Old 07-25-2005, 03:16 PM
Zeke's Avatar
Call Stoddard for the bushings. The pins are much harder than the bushings, so they are not apt to wear. Take them out and check them with a mic.
Old 07-25-2005, 04:37 PM
Thanks Zeke stoddards has them in stock 2.00 each I will have them in 2 days.
1986 blk 930
2000 expedition
Old 07-25-2005, 05:48 PM
Your local dealer should carry the bushings. The bushings will need to be reamed and filed to fit once installed. You will need an 8mm (if I remember correctly) ream to do the job correctly.
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 07-25-2005, 05:53 PM
Zeke's Avatar
Dean
Not my local dealer. They had to order a sump plate gasket for my 2.2. A sump plate gasket?? this means they haven't even changed oil in a 911 air cooled in a while, eh? Or they would have if I would have been stupid enough to stand there while I could be on the phone with Pelican and half way there by the time the dealer finished the paperwork and took my money.
(OK, we have had this discussion many times before. So don't everyone talk bout dealers) Stoddards is special. Owned by the factory, I'm told, and keep a lot of hard to find parts.
Old 07-25-2005, 05:59 PM
This is the first time I talked to a dealer and they were nice, my local dealer changed the belts in my 944 five miles later I eat my top end they say not there fault.My local dealer sucks . The Stoddard dealer was veryhelpfull for a two dollar part not bad.Thanks again
1986 blk 930
2000 expedition
Old 07-25-2005, 06:13 PM
afaik Stoddard was married into the family and his shop was one of the early dealerships in the US. Maybe even the first. If any US dealership gets the factory's attention Stoddard does imo.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-26-2005, 12:37 AM
